- Oct 11, 2003
- Gainesville, FL
I put this topic here because it deals with pelts.
So, I have this problem.
I want to go WC, but I don't want to hack up my beautiful Coolermaster Wave Master, which does not have a nice place to put a good radiator. So, while I should have been no doubt studying for something, I thought up something that could work, and I figured I'd bounce the idea off of ya'll.
You take some copper pipe of, say, 3/8"ID, and bend it back and forth so you have a nice tight zig zag (with the pipes as close as possible--even touching). Then, where a radiator would normally have fins on these pipes and blow air across them, you put a peltier (or several) on the side (or both sides). Then a short passive heatsink . This way you don't have to have good air flow through the heat exchanger, because you've got pelts to cool it. Basically a thermoelectric radiator.
You'll want good case cooling I'd assume to get that heat out of there, but I've got a 120mm delta and a 120mm in my Fortron for exhaust, so that's covered (and an 80mm TT SF2 blowhole...forgot about that one ). With the TEC's it should be pretty effecient at removing heat, so it could be smaller than a radiator (say 80mm square or so). 8 pelts (4 per side, say 40mm square each, Qmax of ~60W each should do eh?)
So obviously there are some problems I see (not impossible to solve though):
1) How the heck are you going to power this? I'm thinking you couldn't just wire up an additional ATX PS to do this huh? Probably a custom (read: homebuilt) dedicated power supply taking up a couple of 5-1/4 bays or more.
2) How much is this going to cost? Copper tubing is cheap, and cheap TEC's at a place like this would be under 100USD
3) How much contact would the pelts be getting with the pipe? A potential concern, if it's a big deal you could do something like fill in the gaps with solder and/or solder a cold plate to the pipes for a nice smooth surface.
That's all I got for now. Any thoughts?
