I received a new protein the other day. Protein 220 / p622_TZ1_NAT. Is shows 200 frames (actually 400) and points are unknown.
EMIII says I have completed 8 out of 200.
Where is the problem? I got this protein right after the server was down for an extended time.
Arguments: -local -advmethods -forceasm
[04:51:10] - Ask before connecting: No
[04:51:10] - User name: weetoots (Team 32)
[04:51:10] - User ID = A95AE9358186E97
[04:51:10] - Machine ID: 2
[04:51:10]
[04:51:10] Could not open work queue, generating new queue...
[04:51:10] + Benchmarking ...
[04:51:13] + Attempting to get work packet
[04:51:13] - Connecting to assignment server
[04:52:20] - Successful: assigned to (171.64.122.119).
[04:52:20] + News From Folding@Home: Welcome to Folding@Home
[04:52:21] Loaded queue successfully.
[04:52:24] - Deadline time not received.
[04:52:42] + Closed connections
[04:52:42]
[04:52:42] + Processing work unit
[04:52:42] Core required: FahCore_65.exe
[04:52:42] Core found.
[04:52:42] Working on Unit 01 [January 19 04:52:42]
[04:52:42] + Working ...
[04:52:42] Folding@Home Client Core Version 2.47 (June 14, 2002)
[04:52:42]
[04:52:42] Proj: work/wudata_01
[04:52:42] nsteps: 5000000 dt: 2.000000 dt_dump: 250.000000 temperature: 296.000000
[04:52:42] xyzfile:
[04:52:42] " 220 p622_TZ1_NAT
[04:52:42] 1 N3 7.132099 -6.099452 -2.777596 124 2..."
[04:52:42] keyfile:
[04:52:42] "parameters ./proj622.prm
[04:52:42] NOVERSION
[04:52:42] ARCHIVE
[04:52:42]
[04:52:42] printout 1000
[04:52:42] writeout ..."
[04:52:42]
[04:52:43] Hashes matched on file work/wudata_01.dyn
[04:52:43] Header on frame 1 differs from expected header
[04:52:43] Got: 2026E-2000B-3E2A2EF7-534BFE3A: 0001
[04:52:43] Expected: 300D2-200062-3E29DDCE-693ABDF: 0001
[04:52:43] Starting from initial work packet
[04:52:43]
[04:52:43] Protein: p622_TZ1_NAT
[04:52:43] - Run: 2 (Clone 11, Gen 2)
[04:52:43] - Frames Completed: 0, Remaining: 400
[04:52:43] - Dynamic steps required: 5000000
[04:52:43]
[04:52:43] Writing local files:
[04:52:43]
[04:52:43] parameters work/wudata_01.prm
[04:52:43] - Writing "work/wudata_01.key": (overwrite) successful.
[04:52:43] - Writing "work/wudata_01.xyz": (overwrite) successful.
[04:52:43] - Writing "work/wudata_01.prm": (overwrite) successful.
[04:52:45] - Writing "work/wudata_01.key": (append) successful.
[04:52:45]
[04:52:45] PROJECT="work/wudata_01", NSTEPS=5000000, DT=2.0000, DTDUMP=25.000000, TEMP=296.00
[04:52:45] TINKER: Software Tools for Molecular Design
[04:52:45] Version 3.8 October 2000
[04:52:45] Copyright (c) Jay William Ponder 1990-2000
[04:52:46] portions Copyright (c) Michael Shirts 2001
[04:52:46] portions Copyright (c) Vijay S Pande 2001
[05:02:46] Finished a frame (1)
[05:12:22] Finished a frame (2)
[05:21:34] Finished a frame (3)
[05:30:51] Finished a frame (4)
[05:40:02] Finished a frame (5)
[05:49:20] Finished a frame (6)
[05:58:37] Finished a frame (7)
[06:07:55] Finished a frame (8)
[06:18:15] Finished a frame (9)
[06:28:55] Finished a frame (10)
[06:38:29] Finished a frame (11)
[06:48:26] Finished a frame (12)
[06:58:41] Finished a frame (13)
[07:09:02] Finished a frame (14)
[07:19:37] Finished a frame (15)
[07:29:40] Finished a frame (16)
[07:40:09] Finished a frame (17)
[07:50:11] Finished a frame (18)
[08:01:18] Finished a frame (19)
[08:11:52] Finished a frame (20)
[08:22:00] Finished a frame (21)
[08:32:12] Finished a frame (22)
[08:41:48] Finished a frame (23)
[08:51:26] Finished a frame (24)
[09:01:04] Finished a frame (25)
[09:10:23] Finished a frame (26)
[09:19:37] Finished a frame (27)
[09:28:55] Finished a frame (28)
[09:38:11] Finished a frame (29)
[09:47:26] Finished a frame (30)
[09:56:44] Finished a frame (31)
[10:05:56] Finished a frame (32)
[10:15:11] Finished a frame (33)
[10:24:25] Finished a frame (34)
[10:33:36] Finished a frame (35)
[10:42:56] Finished a frame (36)
[10:52:11] Finished a frame (37)
[11:01:33] Finished a frame (38)
[11:10:47] Finished a frame (39)
[11:20:00] Finished a frame (40)
[11:29:15] Finished a frame (41)
[11:38:34] Finished a frame (42)
[11:47:52] Finished a frame (43)
[11:57:09] Finished a frame (44)
[12:06:25] Finished a frame (45)
[12:15:45] Finished a frame (46)
[12:24:58] Finished a frame (47)
[12:34:16] Finished a frame (48)
[12:43:30] Finished a frame (49)
[12:52:48] Finished a frame (50)
[13:02:03] Finished a frame (51)
[13:11:23] Finished a frame (52)
[13:20:39] Finished a frame (53)
[13:30:00] Finished a frame (54)
[13:39:17] Finished a frame (55)
[13:48:33] Finished a frame (56)
[13:57:52] Finished a frame (57)
[14:07:11] Finished a frame (58)
[14:16:25] Finished a frame (59)
[14:25:42] Finished a frame (60)
[14:34:59] Finished a frame (61)
[14:44:14] Finished a frame (62)
[14:53:35] Finished a frame (63)
[15:02:56] Finished a frame (64)
[15:12:12] Finished a frame (65)
[15:21:26] Finished a frame (66)
[15:30:41] Finished a frame (67)
[15:39:59] Finished a frame (68)
[15:49:21] Finished a frame (69)
[15:58:38] Finished a frame (70)
[16:07:56] Finished a frame (71)
[16:17:13] Finished a frame (72)
[16:26:31] Finished a frame (73)
[16:35:43] Finished a frame (74)
[16:45:01] Finished a frame (75)
[16:54:19] Finished a frame (76)
[17:03:29] Finished a frame (77)
[17:12:49] Finished a frame (78)
[17:22:04] Finished a frame (79)
[17:31:18] Finished a frame (80)
[17:40:32] Finished a frame (81)
[17:49:47] Finished a frame (82)
[17:59:04] Finished a frame (83)
[18:08:17] Finished a frame (84)
[18:17:32] Finished a frame (85)
--- Opening Log file [January 19 18:23:49]
# Windows Console Edition #####################################################
Folding@home Client Version 3.24
http://foldingathome.stanford.edu
email:[email protected]
[18:23:49] - Ask before connecting: No
[18:23:49] - User name: weetoots (Team 32)
[18:23:49] - User ID = A95AE9358186E97
[18:23:49] - Machine ID: 2
[18:23:49]
[18:23:49] Loaded queue successfully.
[18:23:49] + Benchmarking ...
[18:23:51]
[18:23:51] + Processing work unit
[18:23:51] Core required: FahCore_65.exe
[18:23:51] Core found.
[18:23:51] Working on Unit 01 [January 19 18:23:51]
[18:23:51] + Working ...
[18:23:55] Folding@Home Client Core Version 2.47 (June 14, 2002)
[18:23:55]
[18:23:55] Proj: work/wudata_01
[18:23:55] nsteps: 5000000 dt: 2.000000 dt_dump: 250.000000 temperature: 296.000000
[18:23:55] xyzfile:
[18:23:55] " 220 p622_TZ1_NAT
[18:23:55] 1 N3 7.132099 -6.099452 -2.777596 124 2..."
[18:23:55] keyfile:
[18:23:55] "parameters ./proj622.prm
[18:23:55] NOVERSION
[18:23:55] ARCHIVE
[18:23:55]
[18:23:55] printout 1000
[18:23:55] writeout ..."
[18:23:55]
[18:23:55] Hashes matched on file work/wudata_01.dyn
[18:23:55] ARC file integrity verified
[18:23:55] Restarting from checkpointed files.
[18:23:55]
[18:23:55] Protein: p622_TZ1_NAT
[18:23:55] - Run: 2 (Clone 11, Gen 2)
[18:23:55] - Frames Completed: 85, Remaining: 315
[18:23:55] - Dynamic steps required: 3937500
[18:23:55]
[18:23:55] Writing local files:
[18:23:55]
[18:23:55] parameters work/wudata_01.prm
[18:23:55] - Writing "work/wudata_01.key": (overwrite) successful.
[18:23:55] - Writing "work/wudata_01.xyz": (overwrite) successful.
[18:23:56] - Writing "work/wudata_01.prm": (overwrite) successful.
[18:23:57] - Writing "work/wudata_01.key": (append) successful.
[18:23:57]
[18:23:57] PROJECT="work/wudata_01", NSTEPS=3937500, DT=2.0000, DTDUMP=25.000000, TEMP=296.00
[18:23:57] TINKER: Software Tools for Molecular Design
[18:23:57] Version 3.8 October 2000
[18:23:57] Copyright (c) Jay William Ponder 1990-2000
[18:23:57] portions Copyright (c) Michael Shirts 2001
[18:23:58] portions Copyright (c) Vijay S Pande 2001
[18:38:20] Finished a frame (86)
[04:51:10]
[04:52:42]
[04:52:42]
[04:52:42] xyzfile:
[04:52:42] keyfile:
[04:52:42] ARCHIVE
[04:52:42]
[04:52:42]
[04:52:43]
[04:52:43]
[04:52:43]
[04:52:45]
[18:23:49]
[18:23:51]
[18:23:55]
[18:23:55] xyzfile:
[18:23:55] keyfile:
[18:23:55] ARCHIVE
[18:23:55]
[18:23:55]
[18:23:55]
[18:23:55]
[18:23:55]
[18:23:57]
