- Sep 23, 2011
My question is; will my 850 watt corsair Hx be able to support a Corsair h100 with the components I already have?
My computer is:
Case : Haf X ( 4 x 200mm fans and 140mm)
i7 2600k (stock cooler)
Asus Xonar essence STX soundcard
2x ASUS GTX 560 ti in SLI
16 GB or Corsair ram (Not sure what it is atm cannot check because i dont have it with me)
OCZ Agility 3 120GB
Seagate 500gb sata 2 Harddrive and a WD Black 1TB Harddrive
Some cheap Optical drive.
PSU: Corsair HX850
I cant remeber the motherboard exactly but from what i know its a ASUS P8-Somthing or other V Pro?
Anyway I wish to know if I add a H100 with the 2 stock fans that come with it will my 850PSU be able to run this?
If no one can answer how could I find out myself how many watts my pc is already using? If so can I just do this with software?
I'd rather not have to buy any external item.
Thanks!
Jawn.
My computer is:
OCZ Agility 3 120GB
PSU: Corsair HX850
Thanks!
Jawn.
