NoL said:Nope greenmaji.
Pressure and temperature are proportional remember.
NoL said:Ethylene r1150's critical temperature is 9C. If you don't have an HX temp of -40C you won't condense it in a cascade, it is definetly a difference.
R401A refrigerant.
It is a zeotrope average pressure blend with temperature glide Dtgl= 4...5К. Physical qualities of this blend are given in tables down. R401A saturated vapor pressure is a bit higher than that of R12 (correspondingly 1,27 and 1,08 МPа at 45 oС).
Depending on operation conditions, cold-productivity of the refrigeration system, where there has been used R12 before, is 5...8 % increased. R401A refrigerant is not compatible with mineral oils, therefore, during retrofit it is necessary to charge the refrigeration aggregate with alkylbenzene oil. Substitution of a filter-dehydrator is also required.
The refrigerant is recommended to use for retrofit in high - (higher than О oС) and mean-temperature refrigeration facilities (hermetic, semihermetic compressors and compressors with open drive), domestic refrigerators and fixed air-conditioners for R12 substitution.
Cold-productivity of the refrigeration system operating on R401A is comparable to cold-productivity of the systems on R12 at boiling temperatures higher that -25 oС. Dependence of saturation pressure on temperature is given on the figure. In the table there are given the results of comparison of theoretical refrigeration cycles at operating on R12 and R401A.
You may have seen it on eBay, or all over the internet. Its called Enviro Safe ES 22A. It is sold as a drop in replacement for R22 and a few others. This refrigerant appeals to many people because it does not require a licence to purchase. This got me wondering, what is ES 22A? After a bit of googling about I found the MS/DS for ES 22A. Here are the specs from the MS/DS sheet converted to celsius.
ES 22A Specs
-42.5c boiling point
0.5066 Specific gravity
467c Auto ignition temp
Propane/R290 Specs
-42.1c boiling point
0.509 Specific gravity
470c Auto ignition temp
The slight differences can be accounted for by barometric pressure and purity of the gas tested.
So it looks like Enviro Safe is selling bottled propane for just about any application that uses refrigerant. From what I have been reading the EPA does not restrict the sale of products like Enviro Safe however there are restrictions on working with and filling refrigeration systems. Interesting ehh?
ES 22A Specs
Propane/R290 Specs
