nikhsub1 said:uhh, not true. A barton at 3Ghz should beat the NW in almost everything.
Drec said:i don't see any bartons at 3ghz around here do you? maybe if you had a triple cascade or somthing...
Uhh there were a lot. Cathar had 2 or 3 that would do 3Ghz on plain water.Drec said:i don't see any bartons at 3ghz around here do you? maybe if you had a triple cascade or somthing...
I think a p4 @ 3.8ghz is a more reliable choice because you hear about more p4's above 3.8ghz than athlon xp's above 3ghz.
apu318 said:Exactly. So if you wanna do an eye for an eye test, a 3.8ghz A64 woudl beat a 3.8ghz P4 in mostly anything.
brakezone said:I would agree that an athlon xp would have to get to about 3ghz to generally compare to a p4 @ 3.8ghz. A P4 at that speed is definitely one FAST cpu. The amd cpu at that speed might be better at some things and the p4 better at others, it all depends upon what we are talking about.
Here is an amusing clip from my A+ certification book...
Just for completeness, heres an even more amusing clip from that same book
{PMS}fishy said:Try everything.
Too bad there are so few 3.8ghz A64s.
Exactly. So if you wanna do an eye for an eye test, a 3.8ghz A64 would beat a 3.8ghz P4 in mostly anything
dicecca112 said:AMD's do work more efficently so there is no need for such high clocks, thats the reason you don't seem them. That is why the top end Intels are 3.8 and the top end AMDs are 2.8
