- Dec 31, 2001
I just built a new computer, and I've been having a problem with my networking.
Actually...everything works fine, except that I cannot access files on my new pc from any other computer. I can view the list of shared directories, and if I add a new shared directory it shows up immediately, but I cannot open any of these directories. Even if I am on the new pc, and I open up \\josh (the computer name) I cannot open a directory. I get this error message:
"\\josh\d is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions.
Not enough server storage is available to process this command"
I am stumped.
My hardware:
Expox 9nda3j motherboard with built in NVIDIA Gigabit LAN card.
The card has a built in hardware firewall, but everything idicates that it is disabled.
The network is based on a Linksys wireless G router. In my room, i split the connection with a Linksys BEFSR v3 because I often have up to 4 computers running at one time. I have disabled DHCP on the second router and set its ip to 192.168.1.2
For a second i thought that i having 2 routers on one network might be causing the problem; however i ruled this out for several reasons.
1. My old computer was able to share files when plugged into the same router.
2. I tested with a different router.
3. All the computers in the network can access each other's files
4. I cannot access my own files.
Software I am using:
XP Pro SP2
Norton AV 2002 (updated)
Zone Alarm (network is on trusted zone, and have tried disabling it)
Windows firewall is disabled.
I have probably missed something simple. Could someone help?
Thanks.
I am stumped.
My hardware:
XP Pro SP2
Thanks.
