- Jan 5, 2001
evga nf41 with the latest beta bios
2x1gb mushkin ddr4000 black
pc&p 510 asl power supply
Opty 165
OSA165DAA6CD
CCBWE 0551 UPMW
1392938L50037
evga 7800gt
winxp pro
Well heres the update (at work trying to recall the settings from memory)
I moved my mushkin ddr4000 series black over to the blue slots on the evga nf41 just to see if it would make a difference and tinkered until about 11pm last night.
Still working via air cooling for the testing purposes.
I can take the HT up to 280 with the cpu at 2580 and have no problems as I long as I do not allow the memory to get over 250. I have done this with both 1T and 2T settings. So for now its 3-8-3-4 stock voltage at 1T
Currently I am at 280ht, 2580cpu with the memory at 240 or there abouts. At that setting I have been able to game, surf, even burned a DVD to check. Ran Sandrasoft and ran some benchmarks, then I ran 2 instances of prime95 for an hour. At idle the temps with the stock air cooler are 33C, when I game or bench test they reached 49C, briefly going 50C and then back. (hence why I like phase cooling, never gets over zero lol)
Have not had a reboot yet as I did previously under cold, but have asked my wife to allow my son time to game on it and have her surf about.
Conclusion so far, the evga board is a decent mid range board, the limitations of the memory (that some major review sights pointed out) are still in effect.
If the system stays stable for 3 days at my current setting I will conclude that under air I have reached a decent and stable overclock point.
I shall then put her back under the Mach 1 and go supercold and using a new set of neoprene, seal string, and sealent make sure that I get a solid seal.
If the reboots restart at the settings the system can handle under air then I must conclude the chip just doesnt like cold or somehow its flucuating enough somehow in the temp that its causing the board to force a reboot?? Really puzzling me
If any guru's out there with experience dealing with cold bugs could give some feedback I would appreciate it. My limited understanding is that the cold bug prevents the cpu from booting up, not causing random reboots or bsod's
Opty 165
OSA165DAA6CD
CCBWE 0551 UPMW
1392938L50037
evga 7800gt
winxp pro
