Hello all!
i am planning an experiment in water cooling that i would like some input on. Before i get into what im going to do i should let every one know that this will be my first time doing a water cooled setup. i have read most of the stickies and understand what i need for the most part, but i definitely need a couple of pointers.
now this experiment is 2 fold. first to see if it can be done this way and to assertain if there is any difference versus it being air cooled. second to teach myself the in's and out's of building a true water cooled system.
now for specs.
the loop is going to be set up on a laptop. yes, a laptop. there are several reasons as to why im using a laptop but top most(after instruction and to see if it works properly) is because of whats been going on with this laptop.
this section is me just ranting about how much of a pain this laptop has been..... you dont have to read it if you dont want to!
the laptop is a Gateway M520/7330/7426(all models are identical except for processor and graphics cards-first two are Intel p4's and the last an AMD Athlon 64) that has been giving me issues for a long time. it started out as a Gateway 7426mx(amd processor) that gave out due to power issues(stopped receiving power from the adapter). i went searching for a new motherboard and found that the intel boards were cheaper and since i didnt care bout graphics on it i figured i would go that route. i got the board and the cpu that is ment for it (ddr mem on all thank goodness) and attempted to bench test it. what happened was nothing....i had gotten a used board that had fried. i rma'ed and ended up with a second the same way. got a refund and got a NEW one. and had the strangest issue...on the internal monitor i would have white vertical bars most/if not all the way across the screen. since i happen to have a second laptop of the same type i double checked the screen. lo and behold it worked fine. when i plugged the board into an external monitor i was actually able to use it. since i had NEVER had this happen to me i researched it and found that i may have a bad board, so a second rm process and a new mobo later same thing happens.....by this point im really frustrated and put the puter on the back shelf. over the next few weeks i get 2 more boards in. one dead and a second one that repeats history.
at this point im giving up on getting this laptop up and running properly, so i decided that im going to rebuild it with out the screen and use it for a testing platform of sorts. so for the first test im going to try for water cooling.
ok now on to what im planning on doing. im going to use the original heatsink/fan combo as my waterblock/radiator. this is what is looks like...
see the copper tubes running from either side to the center area. well they are soldered to a copper block about 1/8 inch thick. these tubes are actully hollow with a copper mesh of some sort in them.
now where i need advice atm is how to attach fittings to the ends of these tubes so i can get a pump and reservoir hooked up as well.
any ideas anyone?
now for specs.
any ideas anyone?
