So what I had planned to just be a CPU GPU upgrade has turned into basically a whole new build (got bit by the bug).
Currently using:
CPU: AMD 720BE @3.4
RAM: 4GB mushkin DDR3
MB: Gigabyte GA-MA790XT-UD4P
PSU: 550w BFG
GPU: EVGA GTX260
Display: 24" Dell LCD ST2410b
Anyway I plan on upgrading the CPU to a 955-970BE and getting 2 6950 to run in CF.
I'd like to go the eyefinity route as I've always wanted that setup and I now have the funds to do so. Mind you I'm still doing this on a budget.
I'm looking at getting at least 2 of these http://www.newegg.com/Product/Product.aspx?Item=N82E16824236102 and pairing them with my ST2410b specs for dell or should I get 3 and just put my current LCD with my old build.
Currently using:
CPU: AMD 720BE @3.4
PSU: 550w BFG
GPU: EVGA GTX260
