Travis Dawes said:
The dimples go all the way out to the edge of the blades. I think the idea is to reduce turbulence rather than to move more air. This may help make the fan more quiet, though it's still not enough to beat the quietest smooth-blade fans in cfm/db.orion456 said:The golf ball dimpled fan looks fun but since 90% of the air a fan moves is from the outer 20% of the fan, the dimples they show on that fan would do nothing.
where are you calculating effective distancw ??ackrungh
you can push the shroud depth to the very minimum effective distance of 3/4", or simply leave the pulling shroud out. However I've calculated that even with 1.5" shrouds
