Thats a HSF unit, with consist of a heatsink(metal parts around the fan), and the fan. There are also 2 holes on the PCB to attach the Corb, so all you have to do is remove the stock HSF. If you are having problem removing it, run 1/2hr of 3dmark and then try to remove it. If that doesn't work, try the freezer trick.
