- Jun 21, 2002
I am running a 2500+ and its hitting 2248mhz easy (1.75v), but temp becomes and issue as I aproach 2300 with 1.8v. (i have hit 2398mhz before but with better cooling that I was borrowing) My case cooling has 2 80mm ins ~30cfm, 2 80mm outs ~30cfm, and a side in over vid ~30cfm. I also have a 120mm psu exhaust. I am planning on adding a Tt thunderblade 120mm (free to me) over the CPU and maybe duct it in (though i would like more air to hit the mosfets, ram and NB too so i dont want it all down onto the HSF. My HSF is a SLK-947u w/ an enermax 92mm running about 60cfm. I know that pressure is a big deal w/ the this HS. I also have heard that 80mms proform a little better. Load noise isnt a big issue b/c i can wear headphones to game, but when idle i want it to be quieter (about where I sit with a CPU fan ant about 40, and 6 other fans at about 30 db)
Thus i am considering:
-Tt or CM counterrotating fan setup
-Tt SFII (though i have heard they are not as good anymore)
-Vantec Tornado @ either 80mm or 92mm w/ sunbeam
-CM centrifugal blower
I would like any suggestions, or info you can provide about these or other setups.
Thanks.
Thanks.
