Stubby5000
- Jun 25, 2017
I'm new to watercooling and I'm trying to tackle a pretty ambitious first build which involves putting the radiator/fan unit into a desk drawer, then having the computer in the drawer below. I will have a two 280mm rads in a dedicated loop for both CPU and GPU. I'm trying to figure out how to control the fans. Ideally I could find a controller that would allow individual control of each loop's fans/pump, with the option for manual and "auto" (i.e., governed by PWM rules in the bios) operation. Does something like that exist? Also, how will I control the pump speed? Is it also controlled with a 4-pin PWM? Are there controllers/hubs that can separate out fan speed and pump speed on the same circuit? Also, can someone explain what this is?
https://www.ekwb.com/shop/ek-cable-pwm-fan-adapter-for-gpu-50cm
Conceptually I understand it, but where does it plug in?
Thanks for the help. As I said, I'm new to this and trying to learn... ;-)
