So I'm working on my next PC build, and after replacing the wraith prism cooler that came with my 2700x with the NHD15 noctua cooler I noticed that the NHD15 can run fanless with similar results as the wraith prism with a fan.
I read that the wraith prism cooler was actually a decent cooler considering it comes stock with the processor. But I noticed that the fan actually makes an annoying winding sound while the processor is overclocked and underload. Also I was a bit disappointed by the machining quality of the cooler itself. (http://www.overclockers.com/forums/...raith-Prism-LED-Cooler?highlight=wraith+prism)
I had to order an AM4 mounting kit for the NHD15 cooler, so I just went ahead and installed the wraith prism cooler. I didn't want to wait another week to use my new PC. Can you blame me? I didn't get a golden silicon lottery winner 4.3ghz processor, but I was able to get 4.2ghz fairly easily with 1.45 volts with the stock wraith prism cooler.
After the mounting kit for the NHD15 cooler came in I removed the cooler from my old pc, and swapped it out with the wraith prism. Without a fan and without changing the overclock at all, I was able to boot right up and run for a while at 4.2ghz. Eventually after about 45 minutes of youtube/reddit/overclockerscom forums my pc hit that thermal limit and crashed. If you look at the pics you'll see that the entire PC is actually inside a metal container. The heat really had no where to go, and my laser thermometer was reading over 125F towards the top of the noctua heatsink shortly after the crash. Right now the CPU is overclocked to just 3.9ghz at 1.2volts and it runs fine even under load without a fan. Does this sound right to you guys?
Later I plan on turning this into an immersion cooled PC. Anyone here know anything about fans designed specifically to be used while immersed in oil? The Noctua fans work for a few months in oil, but eventually **** the bed. So I'm thinking of getting a water chiller (You know the chillers they use for indoor gardening?) Do you guys think that these chillers would have problems pumping mineral oil? Anyone have any suggestions on a device that could chill around 10 gallons of oil from maybe 50C to 35C?
https://ibb.co/jO6p78
https://ibb.co/mzrBLT
