- Nov 3, 2008
Still won't be practicle on a CPU lenny. I don't care how much the air is agitated and pissed off The concepts are fine but this can NOT (Read NOT) properly deal with the rapid heat changes in a CPU. If the base that were mounted to the CPU were thick it would make a big diffrence but then you have to wic more heat through the air. Sure it will work but the hype is just that. This may break 3Ghz as the article says; that will be 3Ghz on a 3.7Ghz CPU
