- Apr 29, 2010
- Central FL
I'm currently having to use the molex plug because it could not power my fans properly just from the motherboard. I have 9 fans on mine; 2 are fans that came with the case and 7 are Yate Loon D12SH running at about 600rpm or so. Without the molex my fans would randomly not start or stop spinning. I have both the molex and the motherboard plug in use and from what I can tell there is still speed control from the motherboard but so far it isn't getting hot enough to max the fans out.Power to the fans is not from the PSU by default. Phanteks explicitly says do not use the 4pin molex connector on the fan hub unless your motherboard is having trouble driving the fans.
I have 8 fans on mine right now (2 front 140mm intake, rear 140mm exhaust, 5 120mm rad fans)
It's my understanding that if you use the molex connector, you lose PWM control from the motherboard.
I assumed the molex was just an additional power source so I have not tried it alone but I would think you are right because there is no control module on the hub. It would just divide the single molex to the fans plugged in. It still needs the motherboard controlling the power output.
