- Dec 19, 2000
- hamilton, ontario, canada
good luck......keep us posted on any positive (or negative) results that result in some thing good (or not so good)
ZmajEly (Jun 05, 2001 09:56 a.m.):
Hi guy's,
Reading this forum, i've find some confusions.
There is NO resistor packs under the CPU from Intel, but capacitors,
you can simply shortcut them and run some test, without any problems.
After that, just remove the shortcuts and problem is solved.
Success,
Elvis
Celemine1Gig (Jun 07, 2001 06:00 p.m.):
where did you see 4 extra ones??????????
Placid (Jun 07, 2001 06:36 p.m.):
The photo on the right has 4 small rectangle objects in the center section and the photo on the left has 6.
sifu quoc (Jun 07, 2001 08:06 p.m.):
very interesting.... so we can try short thingy's then??? by bridging them together???
what about the 4 extra rectangles....
there seems to be an extra circle on the bottom too...
i'm not sure if the cirlce thingy lines up...
there are only 2 circles on the unlocked pIII, but 3 circles on the locked one....
just pointing out what i see...
