I’m happy with my current water-cooling setup but its wall-mounted and very clunky. I’m moving into another flat which is directly under the roof and it can get very hot in there when the sun hits the roof. I also have access to the basement so I’ve decided to get my hardware off the wall and put it into a portable case and just work in the basement when its too hot. Thus Ill be switching between the basement and flat a lot. Sadly I couldn’t find any portable case that fits my needs. The only one I could find that was kinda fitting is the Fractal Design Define R5 White. But I have some beef with it: 1. its not portable, I could drill holes in it and add handles but Id rather not mess with a 100€ to 200€ case. 2. I have to use my 360 rad at the top which eliminates the soundproofing and dust-filtering. BUT it has 2 optical slots and enough hard-drive-cages. I need that. I’ve got 6 HDDs: 3x 2.5 and 3x3.5, one optical drive and one HDD quick exchange that fits 1x 3.5 and 1x 2.5 HDD which uses one optical slot to mount.
I also need to add a reservoir and pump. I currently use a submersible pump in a huge external diy glass reservoir. To make everything portable I’d need to change this. But I’m not sure what res to get. A slim res&pump combi would be best. But I have problems finding one, most are cylindrical and look like they wont fit in with all those HDDs. The slim and stealthy ones I’ve found take up an optical slot which isn’t available.
