- Dec 10, 2004
- Thread Starter
- #61
ochungry said:Radioshack sells 15watts for $9 I think. but have to buy a narrow tip for it too ($1.50 I think). they have several, make sure you get the one that is narrow shaft and 15 watts.
I dont know any other way, except the nailpolish method.
Edit: I was wrong. Its only $7.99 and it already has a narrow tip
http://www.radioshack.com/product/i.../00000999&kw=soldering+iron&parentPage=search
EDIT2: I have not tried this, but it is interesting, for 97c cents. maybe heating a coathanger would work w/ this?
http://www.radioshack.com/product/i.../00000399&kw=soldering+iron&parentPage=search
EDIT3: you can buy the same kind of resistors (SMD's ) that looks exactly like the resistor # 1 from Fry's and glue it on top of existing using that silver paste on the ends (or conductive pen). This might work and is less trouble, + inexpensive. A 1k resistor will give you about 2.82v. a 800ohm should give you 2.85-2.90. This is mounting right on top of Resistor #1 (do not remove existing).
I seem to have lost the link to the procedures... with pics.
I'll dig around..
How can you tell if the vdimm mod is sucessful? are you using a Multimeter? I have a bunch of test equip---fluke etc... Wht contact points are being measured and when (power off or on?)?
I'd rather go with the best method.... For 7.99 no brainer
Is there a list of what I need...
Resister...
What type of solder....etc????
I have to go to Radio shack anyway....
