- Jun 28, 2012
Don't apologize! This is the place to go for questions, and I've found a lot of help here.
If I were building a $1,000 rig (not including OS), here's what I would do:
Case - Corsair C70 - $120.33: http://tinyurl.com/kcy39rx
PSU - SeaSonic G Series 550W - $79.99: http://tinyurl.com/mx4djdy
Mobo - ASUS Z87 Pro - $199.99: http://tinyurl.com/kjtnoc9
CPU - Intel i5-4570 $199.29: http://tinyurl.com/kuv4n8k
RAM - G.SKILL Ripjaws 2x4GB - $78.28:http://tinyurl.com/mcnkfmm
Video - GTX 760 - $249.99: http://tinyurl.com/khzsw3z
HDD - WD Black 1TB - $89.99: http://tinyurl.com/lmvl5r9
Optical - LG Blu Ray - $69.95: http://tinyurl.com/m2htt9s
Total Price: $997.82
I didn't shop around. I just looked on Amazon. All of those are Prime-qualified which means free shipping if you're a Prime member.
Don't worry about an after-market heatsink and fan. The one Intel includes with their CPU is specifically designed to cool it and you don't need anything different if you're not overclocking.
Put your money into the graphics card, mobo and the CPU for gaming. Memory is great, but you don't need to max out your mobo and you don't need to get ultra-high performance RAM either.
For the PSU, buy a quality PSU and it'll last for quite a while. Look for 5 year warranties.
For the mobo, look at USB 3.0 and SATA III.
For the case, you want it to be roomy for good airflow and so you can add fans, etc. later. I like Corsair because I think the build quality is great and this case is a nice one, and not horrendously expensive.
I skipped the SSD, because while those are great, I think it's better to spend the money on higher-quality stuff everywhere else and add the SSD later.
Each one of those parts are made by high-quality and well-known manufacturers with good warranties and reputations.
Thoughts?
For that build, drop the $200 motherboard and get one of the cheaper 1150 boards. You can't OC the CPU, so you don't need that motherboard.
After a small OC though, that FX-6350 will outperform the i5-4570.
