Hello! This is my first post here at Overclockers.net. I have been browsing for a while trying to learn as much as I could. I have never built my own PC so I'm a bit of a noob. I have wanted to do my own tower build for a while now. Specifically, a high performance gaming tower. I would also like to learn how to overclock to safe levels. I have set a budget of about $1500 (money isn't a huge issue, but I want to stay reasonable as there's no need for me to spend more than what I need, especially when technology changes so rapidly, at the same time I still must have all very high quality parts).
I already have an OS, monitor,mouse,keyboard. I have done quite a bit of research over the past few weeks on each part and on highly recommended components. Here is my tentative build below. There are a few pieces I am seeking advice on and those are noted below. It would be incredibly helpful and awesome if I could get some advice from some of you knowledgeable people here.
Case - COOLER MASTER HAF 912 | http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
I'm up in the air with this. It looks like a solid case and is extremely cheap at under 60 bucks. As long, as it will fit the components I want, I think I would be happy with it. At the same time, please let me know If any of the parts I've chosen will have a problem with this mid case. Also, if there is another case someone really recommend under 100 bucks, please let me know. It must be a mid tower though. I watched a review and it said this case didn't have a removable motherboard tray. Is this something I should be concerned about or may be a nice feature to have?
PSU - Corsair AX850 | http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139015&Tpk=ax850
I've read a PSU is worth a good investment, however I'm still confused on how to measure the wattage needed. Will 850w be enough If i want to do some further add ons? I guess I'd rather go over than cut it close. Again, any insight or recommendations on a PSU would be great.
CPU - Intel Core i5-3570K | http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Pretty much settled on this one after doing a bit of research. Lol @ my previous view on i5 vs i7. Hoping to overclock to 4.2-4.5ghz.
MOBO - ASRock Z77 Extreme4 | http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
These are the kind of products I get excited about. Is this a worthy motherboard? Price is killer, and seems highly recommended around here. Seems to have everything I need. Any concerns?
Memory - G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 | http://www.newegg.com/Product/Product.aspx?Item=N82E16820231429
Is this the best memory I can get? Anyone recommend or have any other favorite brands? Would I ever need more than 16gb?
HSF - COOLER MASTER Hyper 212 Plus | http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Still researching this one. I've seen this cooler mentioned a lot. Is a cpu cooler all I need to moderately overclock to say 4.2-4.5ghz? I've read this isn't the best but would work for moderate overclocking and I would be okay with spending up to maybe 70-80 on a fan depending on the performance I could get out of it. Which is the best guys?
GPU - EVGA SuperClocked GeForce GTX 680 2GB 256-bit GDDR5 | http://www.newegg.com/Product/Product.aspx?Item=N82E16814130769
Any insight here? A pre-overclocked card looks like the best bet for me. I understand 2gb is enough if I'm only at 1080p. Any thoughts on this? I don't want to spend over $500. Also will this card fit the case I listed? Will it fit 2 if I plan to SLI these cards down the road? Will a 850w PSU hand 2 of these SLI?
Storage - OCZ Vertex 4 256 SSD | http://www.newegg.com/Product/Product.aspx?Item=N82E16820227792
Will be enough for me to get started. I have an extra hard drive sitting around for storage, but definitely want to get an SSD. Any favorite brands or recommended SSD's?
ODD - ASUS DVD Burner | http://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204
yada, yada, yada
Did I miss anything? Total right now above comes to right around $1400. I might also buy some extra case fans depending on the case I get.
I think that's it. Looking to purchase this build this week. Please let me know what you guys think and give me any advice you have! Thanks!
yada, yada, yada
