Hello,
I have just finished my shopping list for my first ever gaming PC with water loop. I read all of the stickys and I think I understand how liquid cooling works in a PC, I hope! Although I think I understand what's going on, I think I still need a little bit of guidance in my first attempt.
My current set-up as of now:
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i7-3930K 3.2GHz 6-Core Processor ($569.53 @ DirectCanada)
Video Card: EVGA GeForce GTX 660 Ti 2GB Video Card (2-Way SLI) ($288.03 @ DirectCanada)
Case: Cooler Master HAF X Blue ATX Full Tower Case ($209.99 @ Newegg Canada)
Power Supply: XFX ProSeries 850W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($104.99 @ NCIX)
Other: Radiator, 3x120mm 30-FPI Copper ($58.64)
Other: CPU-370SI Water Block (Intel Processor) ($58.64)
Other: Reservoir and Pump, RP-1005 (Rev.2.0) ($229.70)
Other: INS-FLTR03 Inline Coolant Filter * 3 ($52.77)
Other: Noctua NF-F12 PWM 120mm Case Fan * 3 ($89.97)
Other: Fitting Pair, Compression for 13mm x 19mm (1/2in x 3/4in) * 3 ($39.57)
Other: Tubing, Blue UV-Reactive PVC, 13mm x 16mm (1/2in x 5/8in) * 5 ($8.75)
Other: Tubing Spring Wrap, Steel Black for OD 19mm (3/4in) ($6.62)
Other: Cold Cathode, 12in UV Dual * 4 ($42.96)
Other: Dual Ultra Bright LED Cable, 4-pin, UV * 8 ($31.20)
Other: EK-FC670 GTX - Acetal * 2 ($215.62)
Other: CrossSLI Danger Den Fittings ($12.95)
Other: IandH Silver KillCoils - Antimicrobial .999 Fine Silver Tubing / Reservoir Strip * 6 ($41.94)
I will be upgrading to a GTX 7xx when they come out, therefore the GPU water blocks are kind of obsolete as of now.
So, I was talking to a friend of mine and told him my expectations of roughly 50-60°C on my CPU and 40-50°C on my GPUs. He told me there was too much restriction and it just wouldn't keep at that temperature.
So, I would like to ask if someone would be able to help me create a good loop that will last and will produce results.
Thanks,
Jacob.
Thanks,
Jacob.
