- Sep 14, 2009
look at a 6300 or a 6350 instead of the 8350, higher clocks with less heat, less to invest in cooling, most games can't use more than 4 cores.
games now are more about the memory and gpu.
I perfer a better single card over sli or crossfire.
Well...right now you are correct. But Battlefield 4 now recommends 6 cores. Personally, I would get the 8350. I was going back and forth for a solid month on either the 6350 or the 8350 and I'm glad I went with the latter.
I think with this generation of consoles we are going to see AMD able to take advantage of 6 and 8 cores. The Ps4 and Xbox are 8 core systems. I have nothing against the 6xxx but if you can afford the 8xxx and the cooler do it. Future proof the thing and OC the crap out of it.
It's going to be really interesting to see how games run over the next 4-5 years on AMD systems vs Intel systems being AMD control the consoles. Intel in ways has dominated and sometimes crushed AMD (look at blizzard titles). But I think that may start to change. It will be interesting to see.
