- Sep 15, 2007
- Small town Emlenton, PA
Physics. Cooler air to the Radiator results in cooler CPU temps in a CPU only loop. Pulling room air through the rad from the room vs the warmer air through the case to the rad as exhaust is simple physics. Must be different with your setup, fannage, who knows.
No way will warm case air to the rad result in cooler temps on the CPU vs room air pulled into the rad.
Maybe your talking only the GPU temps or other Mobo chips. Your GPU must be sensitive to the 3-4C if that higher temps, maybe you need better case flow or need to watercool your GPU too.
Not sure about your full testing, but physics doesn't work like that.
