I finally found what seems to be a stable 4ghz OC on my I7 950. The only issue I have with it is it is running a little hotter than I would like. I would like someone who knows more about overclocking (and maybe has experience with the 1st gen I7's like this) to tell me if this looks ok or if something is off:
My system is I7 950
Noctua NH-D14 with thermal paste that came with it
24gb G skill Sniper DDR3 1600
GTX 970 FTW
EVGA 650 GQ PSU
OC settings are:
191 x 21 to get 4ghz
RAM is running at 762mhz
uncore set to twice the ram
speedstep off
turbo off
no power saving stuff turned on right now
CPU voltage is set to 1.28v
DRAM voltage 1.564
VTT 1.27
PLL 1.90
IOH and ICH along with everything else is set to auto still as I don't really know what they do. I set them to 1.2 in one test but didn't see much of a difference.
During full load, my temps are around 79c after a while of small FFTs.
It was more like 75-76 before I bumped up the VTT from 1.2 to 1.27 but seemed like I needed it for stabilty.
I also tried a CPU voltage of 1.264v but it seemed to be about the same temps.
Is this temp ok?? I think the reason I bumped up the VTT originally was cause I failed the blend test but was passing small FFT. After doing that it went totally stable but added a few degrees to the max temp.
Thanks.
My system is I7 950
GTX 970 FTW
EVGA 650 GQ PSU
OC settings are:
speedstep off
turbo off
DRAM voltage 1.564
VTT 1.27
PLL 1.90
Thanks.
