Hello,
I have very little experience overclocking but understand the basic process. I am attempting to overclock my AMD Phenom X3 8550 Toliman 2.2GHz on my BIOSTAR MCP6P M2+ 6.X motherboard.
When I pull up BIOS and navigate to the CPU Settings I see the following options:
Virtualization: Enabled
AMD k8 Cool & Quiet Control: Enabled
CPU-NB FID: 1800MHz
CPU DID: CPU Freq/1
CPU FID x11 : 2200 MHz
AMD CPU Stepping
By default all the CPU* fields are disabled. I can enable them by disabling "Cool and Quiet".
The problem is, if I try to change CPU FID or CPU-NB FID they are by default set to the highest setting (1800/2200 respectively). They are option menus as opposed to textual inputs so I can't seem to increase these values.
Does this mean the CPU is not overclockable? Or am I missing something?
Thanks for the help.
CPU-NB FID: 1800MHz
CPU DID: CPU Freq/1
AMD CPU Stepping
