- Jan 18, 2011
Computer specs...
Asrock 880G Extreme3
Fractal Design Integra 500W
1TB Samsung Spinpoint F3 HD103SJ
AMD Phenom2 X2 555 3,2GHz BlackEdition
Corsair 4GB (2x2GB) Value Select DDR3 1333MHz
xfx radeon hd5770
So here is the deal, this is my first built pc. I built it, spent 3 days working on a project and didnt play with it at all, and then yesterday I finally sat down with it and SOMEHOW it unlocked itself to the AMD Phenom(tm) II X4 B55 Processor without me doing ANYTHING.
You can find some pics here of the asrock oc tuner specs and some occt readings
and here you can find pics of my bios i took this morning
http://picasaweb.google.com/116969 [...] 7/Computer
You can see the ucc is now enabled, that is because i selected it this morning since it is already unlocked...
Also I increased the cpu voltage through the asrock oc tuner but it went back down to 1.3. I cranked it back up to 1.35 again and its holding.
I ran prime95 for 10 hours last night and it shows no errors. The temp was sticking to around 60 but is down to 43 now. I plan on running occt today some more as well.
What else can/should I do to respond to this sudden increase in cores? I am honestly terrified of overclocking and ruining some part of my new system. It worries me even more that it happened on its own.
I would LOVE any advice about what might have caused this and what I should do.
Oh, and I dont know if it is worth noting but the only odd things that have happened since I built this was one bsod (which was fixed with a reboot), the clock and date randomly changing (in both bios and windows), the quick launch area of windows acting very odd at times, and the windows experience index giving me an error since the other cores opened up.
How can I test to be sure the extra cores are performing correctly, and what changes should I make to my system to accomodate the new cores other than increasing the cpu voltage. Also, I ran AMD overdrive and did the benchmark and stability tests. I dont know how to read the results other than the stability showed all green, but the benchmark went down from high 7000 to low 7000 after the cores became mysteriously unlocked.
Thank you all.
xfx radeon hd5770
Thank you all.
