Hey Guys,
I am tinkering around with the idea of making a custom desktop and I can use some suggestions! Here is the setup I am thinking about getting! Do you guys think this is a good setup? Is everything compatible with the each other? What would you change?
For starters, I have the computer case which is the Antec Three Hundred Two Gaming Case, Black
http://www.amazon.com/Antec-Three-H...&ie=UTF8&qid=1390022119&sr=1-1&keywords=Antec
Or the Antec One Computer Case.
http://www.amazon.com/Antec-One-Computer-Case/dp/B006TVQU6C
For the motherboard I picked the ASUS P8H67-I DELUXE <REV 3.0> LGA 1155 SATA 6Gbps and USB 3.0 Supported Intel H67 DDR3 1333 Mini ITX Motherboard.
http://www.amazon.com/P8H67-I-DELUXE-REV-3-0-Motherboard/dp/B004QF0VFE
The power supply, Cooler Master GX - 650W Power Supply with 80 PLUS Bronze Certification.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171052
The CPU, Intel Core i5-3570K Quad-Core Processor 3.4 GHz 4 Core LGA 1155 - BX80637I53570K
http://www.amazon.com/Intel-Core-i5-3570K-Quad-Core-Processor/dp/B007SZ0E1K
With the memory, Corsair XMS3 8GB (2x4GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMX8GX3M2A1600C9)
http://www.amazon.com/Corsair-2x4GB-Desktop-Memory-CMX8GX3M2A1600C9/dp/B0042A7CAA
The graphics card, XFX AMD Radeon HD 7870 2GB GDDR5 2DVI/HDMI/2Mini DisplayPort PCI-Express Graphics Card FX787ACDFC;FX-787A-CDFC
http://www.amazon.com/XFX-DisplayPort-PCI-Express-FX787ACDFC-FX-787A-CDFC/dp/B007MJGMYA
The Blu-Ray player, Asus Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-Ray Drive (BC-12B1ST)
http://www.amazon.com/Asus-DVD-ROM-...023921&sr=1-1&keywords=blu+ray+drive+internal
And finally the hard drive, WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX.
http://www.amazon.com/WD-Blue-Deskt...&sr=1-2&keywords=1+TB+SATA+III+7200+RPM+64+MB
Do you guys think that this is a good setup? This whole setup costs about $900 bucks. If you guys have any suggestions to make my setup a little cheaper? I would appreciate any help given!
Thanks,
-Josh
Thanks,
-Josh
