Hi Guys,
First time to water cooling and been searching quite a bit and this is what I've come down to and looking for some feedback.
Current setup:
Case - Lian Li pc-011 dynamic
CPU - 9700K
GPU - EVGA 2080TI FTW3 Hybrid Ultra Gaming
Rig pic:
https://ibb.co/kHtKchP
Both the CPU and GPU are currently overclocked pretty aggressively (5GHZ for CPU and 2.1MHZ GPU).
Water cooling Setup:
- CPU Block - EK-Velocity RGB - Nickel + Plexi
- GPU Block - EK-Vector FTW3 RTX 2080 Ti RGB - Plexi + Nickel
- Pump/Reservoir - EK-XRES 100 Revo D5 PWM
- Radiator - HWLabs 360 GTS
- Fittings - EK-ACF x 10 (enough?)
- Tubing - LRT Primochill
- Fans - ML120 Pros
- The EK configurator throws in an EK-ATX Bridging Plug. What purpose does that really serve?
Questions:
- Will I benefit from having 2 radiators vs 1 for both the CPU & GPU?
- Am I over doing it with 360 radiators vs just going 240?
- I'm going to skip the backplate as I hear it's mostly for aesthetics. Thoughts?
- What's the best tool to cut the plastic tubing?
Current setup:
CPU - 9700K
Rig pic:
- Fans - ML120 Pros
Questions:
