As the title suggests I am starting my first watercooling build soon (once the asus X99-E WS is available over here in about 2 weeks)
I will be watercooling a 5820k and a 7990. My case is a Fractal Design Define XL R2.
Going to use noctua industrialPPC fans for the 360 alphacool Monsta radiator mounted in the front of the case.
I was wondering how you can easily mount a pump/res config (res needs to have multiple inlets on top) to the front 360mm radiator.
Which components would you recomend?
At the moment I am thinking D5 with bitspower modtop modkit and top-upgrade-kit (res) and Z-cap (to give the top of the res multiple openings)
I think the best way for me to mount it is via a 120mm bracket to the radiator (found a Z2 pump bracket for that)
I'll send more questions your way as I look trough components and will probably need some people to do a sanity check
make sure it'll all work together and that I didn't make some silly mistake along the way.
