Hi guys/gals
im a first timer with an kind of OC'in and would like some feed back..
at the moment my system is as follows...
Abit IP35 Pro
Intel Q6600 (Kentsfield) 2.40ghz
4 GB Kingston DDR2 (PC2-6400)
Asus HD6970 2gb
im looking to upgrade this soon (April 2012) so thought what better time to have a go at OC'in
i have read a few different things from different sites, and can say im not quite sure if i understand it all... The following is what i have changed and just wanted insight into whether im doing it right
in order of what i did...
External Clock from 272MHz(x9) to 400(x8)
DRAM Speed from Default 1:1.25
PCI-Express Clock from 100Mhz to 101Mhz
CPU Core Voltage to 1.45V
DDR2 Voltage to 1.8
MCH 1.25 to 1.37
CPU VTT 1.2 to 1.27
ICH 1.05V to 1.15V
ICHIO 1.50V to 1.55V
Disabled C1E and EIST Functions
i then set the ram timings as follows...
CAS Latency to 5
RAS# CAS# Delay to 5
RAS Precharge to 5
Precharge Delay to 18
Also set the Init Display First to PCIEx
i will take some screen shots of CPU-Z and HWMomitor
Thanks for reading, and for any advice!!
Abit IP35 Pro
Asus HD6970 2gb
DDR2 Voltage to 1.8
MCH 1.25 to 1.37
CPU VTT 1.2 to 1.27
ICH 1.05V to 1.15V
CAS Latency to 5
RAS Precharge to 5
