- Jul 15, 2007
- Norwich, England
Fist off, hey all, been reading reviews here for some time
Ok, I've spent the past couple of weeks trying to decide where to go with my watercooling set up.
I was originally gonna buy the Zalman, then learnt that it isnt worth a penny, though it does look pretty.
I then decided to buy the Swiftech Ultra+ after reading good reviews.
The more I ggot involved in it, I soon learnt that its still better to go custom. Now its all gotten rather complex, and Im a sucker for bang for buck.
So I finally picked a pump, and went for the Swiftech MCP655 12 VDC Pump (delivered on Tuesday). Which I read its worth sticking with the maximum setting, but after getting confused and some what enlightened reading Cathars The impact of tubing sizes thread, I guess I can actually turn the flow rate down.
Also I have now decided to go with 7/8" tubing. I cant be arsed with playing with a heater core just yet (maybe when Im more confident having water in my beloved box), so I figure Black ICE GT Stealth III will do, as its looks pretty. I have also decided to go for a passive cooling resorvoir, just to help with the heat dissipitation.
Now, for now Im just going to run the CPU block. This is where im getting frustrated. I originally settled for the DD RBX. Then read its a ***** to get a good seating on the core with, so decided against that.
So up stepped the Swiftech Storm, guess what? cant find anywhere to buy it in the UK
So thought about the Apogee for a while, then read a decent review on the DD TDX. So I guess thats the winner, unless you good chaps can enlighten me on something sweet?
I was also thinking of shelling the extra cash out on Fluid XP+, just to be on the safe side. Though I want to know how detremental it really is in terms of carrying heat. Of course Ive read it actually addfs about a degree, though in practical use, im not so sure how true that statement is.
My specs are:
C2D E6600 (I am currently OC'd, and will continue to do so with the watercooling)
Asus P5B Deluxe
BFG 7950 GT
4x1 GB OCZ XTC platinum revision 2
5 HDD's
Its all tucked away in a rather brimming Antec P180. So space is pretty tight, though Im really only going to attempt to mount the pump in the case.
The res and rad im planning on attaching under the desk on the 11" deep board that runs the length of the desk.
Im pretty confident with my Dremel, so modding isnt much of a worry, though I dont want to make my pretty case look bodged.
Please advise where you can, Im budgeting about £160 (the pump was £62 delivered, so about £100 left) out on the kit.
Not worried about GPU cooling just yet, thats another adventure.
So the real question is, what really is the best CPU block to get my filthy hands on?
Also what other advice can I steal from your experienced minds?
Thanks
Eclectic
My specs are:
Asus P5B Deluxe
BFG 7950 GT
5 HDD's
Thanks
Eclectic
