Human0Target
- Jun 15, 2016
Hi All,
This will be my first watercooled build, and wanting some advice (starting the cooling portion of the build now, but system wont be for another 2-3 months)..
I'm looking to keep this machine as quiet as possible for recording audio, but it will be a games machine.. it's replacing an Intel i7-3930K system with SLI'd GTX670 Gfx cards...
System:-
Phanteks Enthoo PRO M
SLI'd GTX1070 (or an equivalent Radeon(s) )
Intel Core i7-6900K (or possibly a i7-6850K)
an X99 Mbd (or its replacement if available)
2* XPG Dazzle 16GB DDR4-3000 CL16
M.2 PCIe SSD boot disk
2* 512GB SSD in Raid 0
Water cooling (somewhat limited here in NZ)
EK-CoolStream XE 360 Radiator (Top Mount)
EK-CoolStream SE 240 Radiator (Front Mount)
EK-SUPREMACY EVO waterblock CPU
2* waterblock for GFX cards
EKWB EK-XRES 140 DDC 3.2 PWM ELITE (INCL. PUMP) (Pump and Resovoir)
plus tubing and fittings..
I'm thinking that the loop will look like this:-
Res->pump-> XE360 -> CPU -> SE240 -> splitter -> GPUs -> back into Res....
Due to issues with my current system I plan on using the rear case fan and top radiator fans to pull air in, and use the front to pull air out so exhausting trough the case front.. at the moment hot air in summer gets trapped under my computer desk, and makes things uncomfortable while sitting at the desk...
Thoughts, Advice.... please help a noob out here
System:-
