This post is kinda a thank you post to all the people who helped me over the web on many forums(including this one) to mount the machine that will idealy match my requirenments, that I hope will serve me for 5+ years(I'm not a serious gamer). Before that I knew very little about hardware, what to get, which companies to look into for certain components, but thanks to all of you I could put together great PC with as little money as possible(considering).
Also, couple people asked me some time ago, to do some pictures when I'm done with my setup, I thought it was kinda cool and to be honest I liked to do pictures of my progress
, and so I did.
Anyways, as I'm not a welthy guy I had to spread the mounting of my PC over many months. I started back in October, it took hell lot of a time on research, ordering and then putting this all together, but now I can safely say I'm done
The case is very queit considering it has air cooling, and 5 fans inside the case + CPU cooling + graphic card cooling and PSU! I can easily set the fans to 30% with SpeedFan in Windows(the lowest speed possible), and still the temps are great + keep things quiet!
That is what I was looking for and I'm glad it's just that.
So again, big thanks to everybody who spend some time in helping me out with some advices and suggestions. I appriciate any post you guys made!
Whole setup:
Fractal Design R3 Black Pearl (USB3.0 port PAnel edition)
AsRock Extreme3 Gen3 Motherboard
Intel i5-2500k CPU + Thermalright Chill Factor III Compound
Thermalright HR-02 MAcho CPU Cooling on ZipTies
4x4GB G.Skill Ripjaws Low Voltage
XFX 550W PSU
Gigabyte GTX 460 OC
Asus Xonar D1 Sound Card
Samsung SSD 830 128GB - System
Seagate 500GB - Inside Storage
Unitek USB3.0 PCI-E Card with 2 external USB3.0 Ports, 1 Internal USB3.0 Port(for Fractal Front Panel's USB3.0 Port) and 1 Molex connector for stable power input
TpLink TL-WN781ND PCI-E + Connectify Software (Access Point for smartfone & Notebooks)
Piooner 212 SATA DVD Reader/Writer
3 Intaking fans: AC 120mm PWM Front1, Fractal 120mm Front2 and Thermalright TR-TY140 140mm PWM Bottom
2 Exhausting fans: Fractal 120mm Rear, Thermalright TR-TY140 140mm PWM Top
External:
24" Iiyama ProLite E2409HDS + 19" Iiyama ProLite E1900S
Thermaltake Black X Duet 5G - USB3.0 Dual docking station for two 2TB Seagate Green external Storage
Logitech k800 Illuminated keyboard
Logitech Performance MX Mouse
Corsair Flash Voyager USB3.0 32GB (wouldn't be a point of having usb3.0 card without it
And this is how it looked over those months:
First shipment
Second shipment
Third Shipment
Fourth, Fifth and Sixth shipments
Final Setup
