- Jan 12, 2001
- Kansas, USA
I'm gearing up for a major rebuild soon. So, I ordered some things for the watercooling loop to do while I have everything disassembled, like new tubing, a couple more barbs, and a kit to swap my Swiftech Apogee GTZ block over to the new socket. I also bought some new Arctic Silver 5, some fan power adapter cables, and a couple of Swiftech universal GPU waterblocks for half price. Why? Because they were half price! Never know when I might get a wild hair and try watercooling two cards in crossfire. Then I looked at flow indicators and bought the Bitspower flow sensor. I've wanted something like this for a long time. These are little devices to visually show you that coolant is flowing through the loop. For peace of mind purposes. You never know when a pump will fail.
This gadget also has "fan RPM" wire that converts the pulse signal to what the motherboard BIOS thinks is fan RPM. So, I'll plug it into the CPU fan header on the motherboard. While this does not truly measure the amount of flow, but, it does monitor fllow the loop. If flow stops, then you can set it to trigger an alarm and/or have the BIOS automatically shut the system down. And lastly, this "thing" is really cool looking (pun intended).
I pulled a random photo off the web to get an idea how people are mounting them. It might be hard to see, but on front side of the round clear window there is a little impeller or fan blade thing. When your water loop is flowing properly, this will spin. The wire connector is on the back side. Whoever set this up did a great job.
Anyone else have this Bitspower Flow Indicator? Any thoughts on where I should install it? On the outside of the case might be nice, but that's a lot of work.
NOTE: This is not my computer.
