Seems like water cooling today is becoming more about looks than actually cooling, I do not use colored coolants or dyes, I don't think they are good products especially for your hardware, but people buy the crap so they keep selling it.
That Thermaltake case is IMO another interesting example of useless bling having your graphics card mounted like that and having to buy the optional PCI-E 3.0 extender to even run the thing?
We see a lot of ideas of good case designs come and go, and I guarantee you that one will eventually disappear, you don't need any more lengths of cables than necessary, or we'd still be running Ribbon Cables.
Foam is either:
#1 That coolant crap you are running (If color is your thing use colored tubing)
#2 You did not thoroughly clean and flush everything before putting it into service!
#3 You have a pin hole leak somewhere (which can when the system is running pull in microfine bubbles, which looks like foam)
Sorry No Offense, Just My Opinion. SS
