Folding crashes overnight
ctag
Hi,
I've been on the team for a while now, but the transition to college upset my involvement quite a bit. Now that it's November, having another heater around sounds like a good idea, so I loaded up my F@H client again.
Overnight (consistently), my computer will soft crash. This doesn't seem to be a problem during the day because I return to my dorm within 6 hours and don't give it the 8 or so it takes to crash... I really don't know.
Symptoms:
After > ~6 hours, the computer will crash. Everything looks FINE, the power LED is on, the screens are in standby, my gaming keyboard is still lit up... But nothing I do will bring the screens back, they stay in standby... I've had to use the power button and hard reset every time this has happened.
The screens "turn off" after ten minutes (set from Win 7 power settings), so it's not just that they're turning off that triggers the problem.
This does not happen at all without the F@H client. My computer will happily run for weeks on end otherwise.
My computer:
AMD 8150 - 4.2Ghz
ATI Radeon HD 5500
AMD Radeon HD 6900
Windows 7 x64 Ultimate
AMD Vision Engine Control Driver:
attachment.php
I can't seem to find the log file after the computer has crashed... I don't know where it's stored on the hard drive.
I'll include a log generated after restarting the client a few minutes ago.
Code:
*********************** Log Started 2012-11-19T14:03:51Z ***********************
14:03:51:************************* Folding@home Client *************************
14:03:51:      Website: http://folding.stanford.edu/
14:03:51:    Copyright: (c) 2009-2012 Stanford University
14:03:51:       Author: Joseph Coffland <[email protected]>
14:03:51:         Args: --lifeline 6384 --command-port=36330
14:03:51:       Config: C:/ProgramData/FAHClient/config.xml
14:03:51:******************************** Build ********************************
14:03:51:      Version: 7.1.52
14:03:51:         Date: Mar 20 2012
14:03:51:         Time: 19:37:42
14:03:51:      SVN Rev: 3515
14:03:51:       Branch: fah/trunk/client
14:03:51:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:03:51:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:03:51:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
14:03:51:     Platform: win32 XP
14:03:51:         Bits: 32
14:03:51:         Mode: Release
14:03:51:******************************* System ********************************
14:03:51:          CPU: AMD FX(tm)-8150 Eight-Core Processor
14:03:51:       CPU ID: AuthenticAMD Family 21 Model 1 Stepping 2
14:03:51:         CPUs: 8
14:03:51:       Memory: 16.00GiB
14:03:51:  Free Memory: 12.72GiB
14:03:51:      Threads: WINDOWS_THREADS
14:03:51:   On Battery: false
14:03:51:   UTC offset: -6
14:03:51:          PID: 6264
14:03:51:          CWD: C:/ProgramData/FAHClient
14:03:51:           OS: Windows 7 Ultimate
14:03:51:      OS Arch: AMD64
14:03:51:         GPUs: 2
14:03:51:        GPU 0: ATI:4 Cayman PRO [AMD Radeon 6900 Series]
14:03:51:        GPU 1: ATI:4 Redwood PRO [Radeon HD 5500 Series]
14:03:51:         CUDA: Not detected
14:03:51:Win32 Service: false
14:03:51:***********************************************************************
14:03:51:<config>
14:03:51:  <service-description v='Folding@home Client'/>
14:03:51:  <service-restart v='true'/>
14:03:51:  <service-restart-delay v='5000'/>
14:03:51:
14:03:51:  <!-- Client Control -->
14:03:51:  <cycle-rate v='4'/>
14:03:51:  <cycles v='-1'/>
14:03:51:  <data-directory v='.'/>
14:03:51:  <disable-project-lookup v='false'/>
14:03:51:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
14:03:51:  <exit-when-done v='false'/>
14:03:51:  <threads v='4'/>
14:03:51:
14:03:51:  <!-- Configuration -->
14:03:51:  <config-rotate v='true'/>
14:03:51:  <config-rotate-dir v='configs'/>
14:03:51:  <config-rotate-max v='16'/>
14:03:51:
14:03:51:  <!-- Debugging -->
14:03:51:  <assignment-servers>
14:03:51:    assign3.stanford.edu:8080 assign4.stanford.edu:80
14:03:51:  </assignment-servers>
14:03:51:  <capture-directory v='capture'/>
14:03:51:  <capture-sockets v='false'/>
14:03:51:  <debug-sockets v='false'/>
14:03:51:  <exception-locations v='true'/>
14:03:51:  <gpu-assignment-servers>
14:03:51:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
14:03:51:  </gpu-assignment-servers>
14:03:51:  <stack-traces v='false'/>
14:03:51:
14:03:51:  <!-- Error Handling -->
14:03:51:  <max-slot-errors v='5'/>
14:03:51:  <max-unit-errors v='5'/>
14:03:51:
14:03:51:  <!-- FahCore Control -->
14:03:51:  <checkpoint v='15'/>
14:03:51:  <core-dir v='cores'/>
14:03:51:  <core-priority v='idle'/>
14:03:51:  <cpu-affinity v='false'/>
14:03:51:  <cpu-usage v='100'/>
14:03:51:  <no-assembly v='false'/>
14:03:51:
14:03:51:  <!-- Folding Slot Configuration -->
14:03:51:  <client-subtype v='STDCLI'/>
14:03:51:  <client-type v='normal'/>
14:03:51:  <cpu-species v='X86_AMD'/>
14:03:51:  <cpu-type v='AMD64'/>
14:03:51:  <cpus v='-1'/>
14:03:51:  <cuda-index v='0'/>
14:03:51:  <gpu v='true'/>
14:03:51:  <gpu-usage v='100'/>
14:03:51:  <max-packet-size v='normal'/>
14:03:51:  <opencl-index v='0'/>
14:03:51:  <os-species v='UNKNOWN'/>
14:03:51:  <os-type v='WIN32'/>
14:03:51:  <project-key v='0'/>
14:03:51:  <smp v='true'/>
14:03:51:
14:03:51:  <!-- Logging -->
14:03:51:  <log v='log.txt'/>
14:03:51:  <log-color v='false'/>
14:03:51:  <log-crlf v='true'/>
14:03:51:  <log-date v='false'/>
14:03:51:  <log-date-periodically v='21600'/>
14:03:51:  <log-debug v='true'/>
14:03:51:  <log-domain v='false'/>
14:03:51:  <log-header v='true'/>
14:03:51:  <log-level v='true'/>
14:03:51:  <log-no-info-header v='true'/>
14:03:51:  <log-redirect v='false'/>
14:03:51:  <log-rotate v='true'/>
14:03:51:  <log-rotate-dir v='logs'/>
14:03:51:  <log-rotate-max v='16'/>
14:03:51:  <log-short-level v='false'/>
14:03:51:  <log-simple-domains v='true'/>
14:03:51:  <log-thread-id v='false'/>
14:03:51:  <log-thread-prefix v='true'/>
14:03:51:  <log-time v='true'/>
14:03:51:  <log-to-screen v='true'/>
14:03:51:  <log-truncate v='false'/>
14:03:51:  <verbosity v='4'/>
14:03:51:
14:03:51:  <!-- Network -->
14:03:51:  <proxy v=':8080'/>
14:03:51:  <proxy-enable v='false'/>
14:03:51:  <proxy-pass v=''/>
14:03:51:  <proxy-user v=''/>
14:03:51:
14:03:51:  <!-- Process Control -->
14:03:51:  <child v='false'/>
14:03:51:  <daemon v='false'/>
14:03:51:  <pid v='false'/>
14:03:51:  <pid-file v='Folding@home Client.pid'/>
14:03:51:  <respawn v='false'/>
14:03:51:  <service v='false'/>
14:03:51:
14:03:51:  <!-- Remote Command Server -->
14:03:51:  <command-address v='0.0.0.0'/>
14:03:51:  <command-allow v='127.0.0.1'/>
14:03:51:  <command-allow-no-pass v='127.0.0.1'/>
14:03:51:  <command-deny v='0.0.0.0/0'/>
14:03:51:  <command-deny-no-pass v='0.0.0.0/0'/>
14:03:51:  <command-port v='36330'/>
14:03:51:
14:03:51:  <!-- Slot Control -->
14:03:51:  <max-shutdown-wait v='60'/>
14:03:51:  <pause-on-battery v='false'/>
14:03:51:  <pause-on-start v='false'/>
14:03:51:
14:03:51:  <!-- User Information -->
14:03:51:  <machine-id v='0'/>
14:03:51:  <passkey v='********************************'/>
14:03:51:  <team v='32'/>
14:03:51:  <user v='BigBubbaX'/>
14:03:51:
14:03:51:  <!-- Work Unit Control -->
14:03:51:  <dump-after-deadline v='true'/>
14:03:51:  <max-queue v='16'/>
14:03:51:  <max-units v='0'/>
14:03:51:  <next-unit-percentage v='99'/>
14:03:51:
14:03:51:  <!-- Folding Slots -->
14:03:51:  <slot id='0' type='GPU'/>
14:03:51:  <slot id='1' type='GPU'/>
14:03:51:  <slot id='2' type='SMP'>
14:03:51:    <cpus v='6'/>
14:03:51:  </slot>
14:03:51:</config>
14:03:52:Trying to access database...
14:03:52:Successfully acquired database lock
14:03:52:Enabled folding slot 00: READY gpu:0:"Cayman PRO [AMD Radeon 6900 Series]"
14:03:52:Enabled folding slot 01: READY gpu:1:"Redwood PRO [Radeon HD 5500 Series]"
14:03:52:Enabled folding slot 02: READY smp:6
14:03:52:WU01:FS01:Starting
14:03:52:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 701 -lifeline 6264 -checkpoint 15 -gpu 1
14:03:52:WU01:FS01:Started FahCore on PID 6448
14:03:52:WU01:FS01:Core PID:2968
14:03:52:WU01:FS01:FahCore 0x16 started
14:03:52:WU03:FS00:Starting
14:03:52:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 03 -suffix 01 -version 701 -lifeline 6264 -checkpoint 15 -gpu 0
14:03:52:WU03:FS00:Started FahCore on PID 3516
14:03:52:WU03:FS00:Core PID:852
14:03:52:WU03:FS00:FahCore 0x16 started
14:03:52:WU02:FS02:Starting
14:03:52:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 701 -lifeline 6264 -checkpoint 15 -np 6
14:03:52:WU02:FS02:Started FahCore on PID 3912
14:03:52:WU01:FS01:0x16:
14:03:52:WU01:FS01:0x16:*------------------------------*
14:03:52:WU01:FS01:0x16:Folding@Home GPU Core
14:03:52:WU01:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:03:52:WU01:FS01:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:03:52:WU01:FS01:0x16:Build host: user-f6d030f24f
14:03:52:WU01:FS01:0x16:Board Type: AMD/OpenCL
14:03:52:WU01:FS01:0x16:Core      : x=16
14:03:52:WU01:FS01:0x16: Window's signal control handler registered.
14:03:52:WU01:FS01:0x16:Preparing to commence simulation
14:03:52:WU01:FS01:0x16:- Ensuring status. Please wait.
14:03:52:WU02:FS02:Core PID:5880
14:03:52:WU02:FS02:FahCore 0xa4 started
14:03:53:WU03:FS00:0x16:
14:03:53:WU03:FS00:0x16:*------------------------------*
14:03:53:WU03:FS00:0x16:Folding@Home GPU Core
14:03:53:WU03:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:03:53:WU03:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:03:53:WU03:FS00:0x16:Build host: user-f6d030f24f
14:03:53:WU03:FS00:0x16:Board Type: AMD/OpenCL
14:03:53:WU03:FS00:0x16:Core      : x=16
14:03:53:WU03:FS00:0x16: Window's signal control handler registered.
14:03:53:WU03:FS00:0x16:Preparing to commence simulation
14:03:53:WU03:FS00:0x16:- Ensuring status. Please wait.
14:03:53:WU02:FS02:0xa4:
14:03:53:WU02:FS02:0xa4:*------------------------------*
14:03:53:WU02:FS02:0xa4:Folding@Home Gromacs GB Core
14:03:53:WU02:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
14:03:53:WU02:FS02:0xa4:Preparing to commence simulation
14:03:53:WU02:FS02:0xa4:- Ensuring status. Please wait.
14:03:54:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
14:04:02:WU01:FS01:0x16:- Looking at optimizations...
14:04:02:WU01:FS01:0x16:- Working with standard loops on this execution.
14:04:02:WU01:FS01:0x16:- Previous termination of core was improper.
14:04:02:WU01:FS01:0x16:- Files status OK
14:04:02:WU01:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:04:02:WU01:FS01:0x16:- Expanded 45176 -> 171163 (decompressed 378.8 percent)
14:04:02:WU01:FS01:0x16:Called DecompressByteArray: compressed_data_size=45176 data_size=171163, decompressed_data_size=171163 diff=0
14:04:02:WU01:FS01:0x16:- Digital signature verified
14:04:02:WU01:FS01:0x16:Project: 11293 (Run 9, Clone 385, Gen 38)
14:04:02:WU01:FS01:0x16:Entering M.D.
14:04:02:WU03:FS00:0x16:- Looking at optimizations...
14:04:02:WU03:FS00:0x16:- Working with standard loops on this execution.
14:04:02:WU03:FS00:0x16:- Previous termination of core was improper.
14:04:02:WU03:FS00:0x16:- Files status OK
14:04:02:WU03:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:04:02:WU03:FS00:0x16:- Expanded 45222 -> 171163 (decompressed 378.4 percent)
14:04:02:WU03:FS00:0x16:Called DecompressByteArray: compressed_data_size=45222 data_size=171163, decompressed_data_size=171163 diff=0
14:04:02:WU03:FS00:0x16:- Digital signature verified
14:04:02:WU03:FS00:0x16:Project: 11293 (Run 14, Clone 57, Gen 40)
14:04:02:WU03:FS00:0x16:Entering M.D.
14:04:02:WU02:FS02:0xa4:- Looking at optimizations...
14:04:02:WU02:FS02:0xa4:- Working with standard loops on this execution.
14:04:02:WU02:FS02:0xa4:- Previous termination of core was improper.
14:04:02:WU02:FS02:0xa4:- Files status OK
14:04:02:WU02:FS02:0xa4:- Expanded 55016 -> 206228 (decompressed 374.8 percent)
14:04:02:WU02:FS02:0xa4:Called DecompressByteArray: compressed_data_size=55016 data_size=206228, decompressed_data_size=206228 diff=0
14:04:02:WU02:FS02:0xa4:- Digital signature verified
14:04:02:WU02:FS02:0xa4:Project: 10083 (Run 4, Clone 39, Gen 64)
14:04:02:WU02:FS02:0xa4:Entering M.D.
14:04:04:WU01:FS01:0x16:Will resume from checkpoint file 01/wudata_01.ckp
14:04:04:WU01:FS01:0x16:Tpr hash 01/wudata_01.tpr:  2282968981 1120165698 241447028 1209631890 118587633
14:04:04:WU01:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:04:04:WU01:FS01:0x16:Client config unavailable.
14:04:04:WU01:FS01:0x16:Starting GUI Server
14:04:04:WU03:FS00:0x16:Will resume from checkpoint file 03/wudata_01.ckp
14:04:04:WU03:FS00:0x16:Tpr hash 03/wudata_01.tpr:  3781215094 2630964835 1582623864 4225874208 2108838116
14:04:04:WU03:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:04:04:WU03:FS00:0x16:Client config unavailable.
14:04:04:WU03:FS00:0x16:Starting GUI Server
14:04:07:WU01:FS01:0x16:Resuming from checkpoint
14:04:07:WU01:FS01:0x16:fcCheckPointResume: retreived and current tpr file hash:
14:04:07:WU01:FS01:0x16:   0   2282968981   2282968981
14:04:07:WU01:FS01:0x16:   1   1120165698   1120165698
14:04:07:WU01:FS01:0x16:   2    241447028    241447028
14:04:07:WU01:FS01:0x16:   3   1209631890   1209631890
14:04:07:WU01:FS01:0x16:   4    118587633    118587633
14:04:07:WU01:FS01:0x16:fcCheckPointResume: file hashes same.
14:04:07:WU01:FS01:0x16:fcCheckPointResume: state restored.
14:04:07:WU01:FS01:0x16:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
14:04:07:WU03:FS00:0x16:Resuming from checkpoint
14:04:07:WU03:FS00:0x16:fcCheckPointResume: retreived and current tpr file hash:
14:04:07:WU03:FS00:0x16:   0   3781215094   3781215094
14:04:07:WU03:FS00:0x16:   1   2630964835   2630964835
14:04:07:WU03:FS00:0x16:   2   1582623864   1582623864
14:04:07:WU03:FS00:0x16:   3   4225874208   4225874208
14:04:07:WU03:FS00:0x16:   4   2108838116   2108838116
14:04:07:WU03:FS00:0x16:fcCheckPointResume: file hashes same.
14:04:07:WU03:FS00:0x16:fcCheckPointResume: state restored.
14:04:07:WU03:FS00:0x16:fcCheckPointResume: name 03/wudata_01.log Verified 03/wudata_01.log
14:04:07:WU03:FS00:0x16:fcCheckPointResume: name 03/wudata_01.trr Verified 03/wudata_01.trr
14:04:08:WU01:FS01:0x16:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
14:04:08:WU03:FS00:0x16:fcCheckPointResume: name 03/wudata_01.xtc Verified 03/wudata_01.xtc
14:04:08:WU03:FS00:0x16:fcCheckPointResume: name 03/wudata_01.edr Verified 03/wudata_01.edr
14:04:08:WU03:FS00:0x16:fcCheckPointResume: state restored 2
14:04:08:WU03:FS00:0x16:Resumed from checkpoint
14:04:08:WU03:FS00:0x16:Setting checkpoint frequency: 500000
14:04:08:WU03:FS00:0x16:Completed   8500001 out of 50000000 steps (17%).
14:04:08:WU01:FS01:0x16:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
14:04:08:WU01:FS01:0x16:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
14:04:08:WU01:FS01:0x16:fcCheckPointResume: state restored 2
14:04:08:WU01:FS01:0x16:Resumed from checkpoint
14:04:08:WU01:FS01:0x16:Setting checkpoint frequency: 500000
14:04:08:WU01:FS01:0x16:Completed  44500001 out of 50000000 steps (89%).
14:04:08:WU02:FS02:0xa4:Using Gromacs checkpoints
14:04:08:WU02:FS02:0xa4:Mapping NT from 6 to 6
14:04:09:WU02:FS02:0xa4:Resuming from checkpoint
14:04:09:WU02:FS02:0xa4:Verified 02/wudata_01.log
14:04:09:Saving configuration to config.xml
14:04:09:<config>
14:04:09:  <!-- Folding Slot Configuration -->
14:04:09:  <gpu v='true'/>
14:04:09:
14:04:09:  <!-- Logging -->
14:04:09:  <verbosity v='5'/>
14:04:09:
14:04:09:  <!-- Network -->
14:04:09:  <proxy v=':8080'/>
14:04:09:
14:04:09:  <!-- User Information -->
14:04:09:  <passkey v='********************************'/>
14:04:09:  <team v='32'/>
14:04:09:  <user v='BigBubbaX'/>
14:04:09:
14:04:09:  <!-- Folding Slots -->
14:04:09:  <slot id='0' type='GPU'/>
14:04:09:  <slot id='1' type='GPU'/>
14:04:09:  <slot id='2' type='SMP'>
14:04:09:    <cpus v='6'/>
14:04:09:  </slot>
14:04:09:</config>
14:04:10:WU02:FS02:0xa4:Verified 02/wudata_01.trr
14:04:10:WU02:FS02:0xa4:Verified 02/wudata_01.xtc
14:04:10:WU02:FS02:0xa4:Verified 02/wudata_01.edr
14:04:10:WU02:FS02:0xa4:Completed 6800001 out of 10000000 steps  (68%)
14:07:21:WU03:FS00:0x16:Completed   9000000 out of 50000000 steps (18%).
14:07:28:WU02:FS02:0xa4:Completed 6900000 out of 10000000 steps  (69%)
14:10:42:WU02:FS02:0xa4:Completed 7000000 out of 10000000 steps  (70%)
14:10:53:WU03:FS00:0x16:Completed   9500000 out of 50000000 steps (19%).
14:14:08:WU02:FS02:0xa4:Completed 7100000 out of 10000000 steps  (71%)
14:14:23:WU03:FS00:0x16:Completed  10000000 out of 50000000 steps (20%).
14:15:08:WU01:FS01:0x16:Completed  45000000 out of 50000000 steps (90%).
14:17:36:WU02:FS02:0xa4:Completed 7200000 out of 10000000 steps  (72%)
14:18:01:WU03:FS00:0x16:Completed  10500000 out of 50000000 steps (21%).
14:21:05:WU02:FS02:0xa4:Completed 7300000 out of 10000000 steps  (73%)
14:21:36:WU03:FS00:0x16:Completed  11000000 out of 50000000 steps (22%).
14:25:01:WU02:FS02:0xa4:Completed 7400000 out of 10000000 steps  (74%)
14:25:10:WU03:FS00:0x16:Completed  11500000 out of 50000000 steps (23%).
14:27:26:WU01:FS01:0x16:Completed  45500000 out of 50000000 steps (91%).
14:28:51:WU03:FS00:0x16:Completed  12000000 out of 50000000 steps (24%).
14:29:13:WU02:FS02:0xa4:Completed 7500000 out of 10000000 steps  (75%)
Thanks,
Is that 12.8 WHQL catalyst driver that you are running?
I honestly don't know. Getting the drivers for both of those cards was a huge pain... Is there some way for me to check?
Yes, go to
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Download the appropriate drvrs and reinstall. Doesn't matter what brand of card.
I've heard groanings on the forums of problems with current and beta AMD drvrs when it comes to folding. But go ahead and reinstall the 12.8 drvrs from the AMD website and maybe one of the AMD 6000 series team members can take it from there.
BTW, I'm folding along just fine using the 12.8 drvrs from the above link on my older HD 5870 presently so I know they work fine on that generation of cards.
Okay, I went ahead and downloaded the 12.10 Win7 x64 driver from the website. Says that it's for the 7000, 6000, and 5000 series.
Thanks man!
:-\ Installer crashed... Hrm.
Might have better luck with the 12.8. Unless there is some benefit to your games listed in the release notes of 12.10 then I would stick with 12.8. Otherwise, sounds like some other issues are at work. Might have to purge the old drivers completely and reinstall as the catalyst drivers don't do a thorough job of removing all traces of the former drivers.
Woah, I can't get 12.8 to uninstall... Windows 7 gives an error from the Uninstall section of the Control Panel, and when I try using the AMD Catalyst it crashes...
Should I open another thread to ask how to completely purge 12.8?
What should I be looking for as far as a culprit for the F@H crashing?
Thanks,
You may benefit from opening a new thread since this problem seems to be driver related. I avoid using driver removal utilities unless I have no choice and only then after a thorough backup of my important data. I used to use driversweeper when I ran into problems rolling back drivers. Seems to have gone the way of the Dodo bird. Some guys are using Atiman's utility. I never have. Maybe one of the other team members can walk you through the details.
http://atiman.go-board.net/f14-forum
Okay, will do. I'll get back afterwards on whether this fixes the crashing.
Edit:
Well, I screwed up my ATI drivers trying to uninstall/reinstall...
I made a new thread pleading for help here.
I'll try F@H again tonight, now that the ATI Catalyst is gone, and see what happens.
Another Edit:
Just realized that LuvToGame recommended Atiman just like someone in my new thread. I can't figure out how to download it from his site though.
Thanks,
Okay,
After quite a few hours of generic stressful troublshooting, I have 12.8 back!
I'm going to load up F@H and see if it's still alive by tomorrow morning... In four hours... x.x
Thanks,
BigBubbaX, i hope it works with what you did, but it may be a bad overclock of the CPU.
I had somewhat similar problem on my Linux cpu-only folder: It also froze sometimes after a few hours of folding, but when i moved the mouse - i did get the screen image, but the comp was frozen - it didnt react to anything so i had to hard reset.
That was fixed by increasing the voltage on the cpu (i7 2600k @ 4.5ghz @ noctua nh-d14), but maybe you have some different issue.
Given that it isn't the graphics card/drivers, having the crash be related to overclocking definitely makes sense. If my computer crashes again, I'll unset the clock back to stock and see if that fixes it :D
Thanks!,
Well,
Last night my computer didn't crash, but it didn't really have enough time to, and it also only produced half of its normal ppd.
It looks like after that driver mess up, I've crippled my computer's graphics abilities...
Hrm, :cry:
You may want to try deleting your gpu slots and creating new ones. I don't recall exactly if I had to do that or not. I know I have done it recently. Also, use gpu-z or msi afterburner to log gpu activity.
Update: F@H crashed while I was in class today... So it's very likely a bad overclock... So it's time for me to run stock until I'm capable of manually OCing.
I'll give the delete/recreate route a shot in a few minutes here.
Edit:
I deleted both gpus from the Configure -> Slots pane. Then I added two new gpus with default settings.
Both still fail without successfully starting or receiving any load.
Another Edit:
I gave up and used System Restore as a last ditch.. Oddly enough, it seems to have worked, which has not been my experience in the past. Anyway, I'm back on 12.8, and I'm going to try running F@H over Thanksgiving break with the AMD processor on stock settings.
Thanks for all of the help!
