I was cleanin up my room today and i came across my old EVGA Nvidia Geforce 8500GT 256MB (Turbo Cached 512MB) PCI-E Videocard...I got curious as to what i could overclock it too...I checked around some forums read that people were overclocking their 8500's to a ridiculous and very unstable amount...So far with Riva Tuner...Ive got this...
Original Specs...
GPU Core 459MHz
GPU Shader Core 918MHz
Memory Clock 400MHz
Overclocked Specs...
GPU Core 630MHz
GPU Shader Core 1260MHz
Memory Clock 510MHz
Updated #1 Overclocked Specs...
GPU Core 650MHz
GPU Shader Core 1300MHz
Memory Clock 510MHz ( So far anything above 530 presented artifacts )
So far these are completey stable specs...Ive been running ATI Tool's Artifact's Scanner for 11mins now and 0 Artifacts (If you get artifacts after overclocking it means its unstable and need to tone it down)...I'm gonna try to overclock it a little more will post with update
Field Value
Graphics Processor Properties
Video Adapter EVGA e-GeForce 8500 GT
BIOS Version 60.86.41.00.01
GPU Code Name G86GT
PCI Device 10DE-0421 / 3842-C741 (Rev A1)
Transistors 210 million
Process Technology 80 nm
Die Size 115 mm2
Bus Type PCI Express 1.0 x16 @ x16
Memory Size 256 MB (TurboCache: 512 MB)
GPU Clock (Geometric Domain) 648 MHz (original: 459 MHz, overclock: 41%)
GPU Clock (Shader Domain) 1296 MHz (original: 918 MHz, overclock: 41%)
RAMDAC Clock 400 MHz
Pixel Pipelines 8
TMU Per Pipeline 1
Unified Shaders 16 (v4.0)
DirectX Hardware Support DirectX v10
Pixel Fillrate 5184 MPixel/s
Texel Fillrate 5184 MTexel/s
Memory Bus Properties
Bus Type DDR2
Bus Width 128-bit
Real Clock 513 MHz (DDR) (original: 400 MHz, overclock: 28%)
Effective Clock 1026 MHz
Bandwidth 16.0 GB/s
Miscellaneous
Fan Speed 100%
nVIDIA ForceWare Clocks
Standard 2D GPU: 650 MHz, Shader: 1300 MHz, Memory: 515 MHz
Graphics Processor Manufacturer
Company Name NVIDIA Corporation
Product Information http://www.nvidia.com/page/products.html
Driver Download http://www.nvidia.com/content/drivers/drivers.asp
Driver Update http://driveragent.com?ref=59
Original Specs...
GPU Core 459MHz
Memory Clock 400MHz
GPU Core 630MHz
Memory Clock 510MHz
GPU Core 650MHz
Field Value
GPU Code Name G86GT
Die Size 115 mm2
Pixel Pipelines 8
TMU Per Pipeline 1
Bus Type DDR2
Bus Width 128-bit
Bandwidth 16.0 GB/s
Miscellaneous
Fan Speed 100%
