- Feb 9, 2012
- Miami, FL
First things first, setup:
CPU: Intel 3930k (stock speeds for now)
Mobo: Asrock extreme6/GB x79
PSU: Cougar cmx 1000w
GPU: Radeon hd 6950 (x2)
CPU cooling: corsair h100i
Case: CM Storm trooper
HDD: two wd 500gb (forgot the type)
and of course
RAM: G-Skill 16gb (4x4) 1600mhz 9-9-9-24 pn xmp 1.5v
on first boot the pc was fine, after half an hour though windows suddenly froze with no bsod. naturally i guessed it was either the psu or the ram because of the lack of a slowdown or bsod and the fact that the monitor display was frozen with performance monitor showing no sudden increases in load or anything like that. I checked all cables and made sure psu was fine. this time when i booted it froze more often, sometimes during boot itself! also at times the pc would boot with a black screen. At this point i removed all the ram and placed 1 stick (this is how i am running it now) and voila it works perfectly as if nothing happened. memtest shows no errors so i am stumped as to what this can be
and yes when i try to place other sticks it goes back to freezing. no overclocks whatsoever and temperatures are excellent so not that either. thanks in advance
and of course
