be carefull, I was using clockgen to reach 265 fsb. Apon a restart as normal as possiable it failed and never restarted again. I needed to get another bios chip to fix it!
TZH: You need to d/l the correct version of Clockgen for your mobo. Be aware, Intel brand motherboards will not OC past 4% and even if you do raise the fsb, the AGP/PCI bus will not be locked.
Clockgen usually only works well with motherboards that you can overclock from the BIOS.
