$200.00 instant rebate-
very good online reviews-
http://www.newegg.com/Product/Product.asp?Item=N82E16834110134
Specs-
Specifications
Model
Brand Fujitsu
Series LifeBook
Model S6231
Part# AQQ0E1A80C001000
General
Operationg System Windows XP Home
CPU Type 1 x Pentium M 725(1.6GHz)
Screen 13.3" XGA TFT
Memory Size 256MB DDR
Hard Dik 40GB
Optical Drive DVD/CD-RW Combo Drive
Graphics Card ntegrated Intel Extreme Graphics 2
Video Memory shared memory
Communication Modem, LAN and WLAN
Card slot 1x Type I/II PC Card Slot
Battery Life 4 hours
Dimensions 11.5" x 9.3" x 1.3"(WxDxH)
Weight 3.7lbs
CPU
CPU Type Pentium M
CPU Speed 725(1.6GHz)
CPU FSB 400MHz
CPU Cache 2MB
Operating Systems
Operating System Windows XP Home
Chipset
Chipset Intel 855GME
Display
Screen Size 13.3"
Display Type XGA
Resolution 1024 × 768
Graphics
GPU/VPU Intel Extreme Graphics 2
Video Memory Shared 64MB
Hard Drive
HD Capacity 40GB
Memory
Memory Slots 2x SO-DIMM
Memory Speed DDR333
Memory Size 256MB
Max Memory Supported 2GB
Optical Drive
Optical Drive Type DVD/CD-RW Combo
Optical Drive Interface Integrated
Optical Drive Spec Write Speed: 24X CD-R; 10X CD-RW; Read Speed: 24X CD-ROM; 8X DVD-ROM
Communications
Modem 56K
LAN 10/100Mbps
WLAN 802.11b/g Wireless LAN
IRDA Yes
Ports
Card Slot 1x Type I/II PC Card Slot
USB 3
IEEE1394 1
Video Port 1 x VGA, 1 x S-Video TV-out
Port Replicator 1
Audio Ports Yes
Audio
Audio SigmaTel AC97 codec with 6 channels stereo sound
Input Device
Touchpad Yes
Keyboard 84-key keyboard with 19 mm key pitch and 3 mm key stroke
Supplemental Drive
Card Reader Memory Stick/SD slot
Power
AC Adapter AC100-240V AC Adapter
Battery 4400 mAh, 4 cell Lithium-Ion Battery
Physical spec
Weight 3.7lbs
Warranty
Manufacturer Warranty One-year International Limited Warranty
Specs-
Specifications
Model
Brand Fujitsu
Series LifeBook
Model S6231
General
Hard Dik 40GB
Weight 3.7lbs
CPU
CPU Type Pentium M
CPU FSB 400MHz
CPU Cache 2MB
Operating Systems
Chipset
Display
Screen Size 13.3"
Display Type XGA
Graphics
Hard Drive
HD Capacity 40GB
Memory
Memory Speed DDR333
Memory Size 256MB
Optical Drive
Communications
Modem 56K
LAN 10/100Mbps
IRDA Yes
Ports
USB 3
IEEE1394 1
Port Replicator 1
Audio Ports Yes
Audio
Input Device
Touchpad Yes
Supplemental Drive
Power
Physical spec
Weight 3.7lbs
Warranty
