Thanks BlueFalcon...
It is a pretty far reaching GIGA problem. A number of their mobo models.
http://forum.giga-byte.co.uk/index.php?topic=12510.0
Vcore problem with a 990FXA-UD3
This double boot problem occurs only when my cpu is overclocked (my cpu is a FX8350 btw). Which mean that even with a 115€ mobo, I just can't overclock my cpu correctly. Fine.
Another person on a french forum, who have the axact same mobo/cpu, told me that he doesn't got this dual boot problem. But his mobo is in rev1.2, mine is rev3.0.
http://www.tomshardware.com/answers/id-1694267/gigabyte-990fxa-ud3-mobo-loop-boot.html
ok, i changed my memory timing settings, i left xmp disabled and manually changed my clock to 9.33 at 1866mhz. that stopped my loop boot on my memory so thank you, but i still get a loop boot if i disable turbo core, im trying to overlock to 4.6ghz at 1.456V. i know im stable at that because ive done a prime test for 8 hours, 22.5x multiplier, but in order to stop my loop boot i have to enable turbo core, which only maxes to 4.1ghz, even if i enable 22.5 multiplier on my turbo core, so i have to have it disabled in order for me to reach my full 4.6ghz. so i guess my question would be...
why is disabling turbo core boost causing my loop boot on cold start?, like i said, it only loops one time, then boots into windows, it doesnt seem to do any harm but to me its just not right, again thanks for posting that timing link, it helped me out alot
http://www.overclockers.com/forums/showthread.php?t=739528
Cold Boot - FX-6350 when I restart my computer it completely shuts off for about 3 seconds and then powers back on. Is this normal? or have I done something wrong?
See post #8.
This sort of crap is why we only recommend boards that we have extensive good experience with. How in hale you going to overclock sumbeeatch when you have TurboCore enabled? CrapOLa.
RGone...ster.
