Hey all im new to the forum
I am having some major problems with overclocking my FX6300
My current setup is
CPU FX6300
MOBO Msi 760gm p34
PSU Thermaltake 500w
CPU Cooler Cooler Master Hyper 212
GPU Gigabyte 1060 6Gb Windforce
HD WD Black 1 Tb
SSD PNY 128 Gb
So my problem is as far I can tell is probably my motherboard at this point but i'm not totally sure, when i turn off turbo core to overclock in AMD Overdrive, even if I bump it just .5 it crashes but im not touch the voltage because i don't know what they should be ; Overdrive is saying volts at 1.25 which i know is low so I don't know what they should be at. I'm not trying to massively overclock this thing maybe to get it 4.0-4.1 would be fine with me until i can get new setup next month. I get this same type of thing if i use the BIOS to overclock ie don't post . Can someone please help me
My current setup is
CPU FX6300
MOBO Msi 760gm p34
HD WD Black 1 Tb
SSD PNY 128 Gb
