JoeDawg210
- Jun 26, 2012
- Nevada Texas
Hello all, first post so be kind and patient!
New build that has burned-in for several weeks with no major issues. Recently disabled the on-board sound for an external Firewire sound card. Ran ~ 1-week fine with no issues. The system is on battery back-up / conditioning and if it is to be down for several days I power-down the back-up as well. To the beef...
Powered-down on Thursday, no issues and everything running as expected. Returned on Monday and attempted to fire-up. System begins boot and then abruptly shuts-down immediately as the bios splash screen flashes.
Opened the case and monitored the onboard LEDs during another boot attempt, all leds lit as the on-board check-out proceeded and then the CPU LED flashed again and the system went down. Happened to touch one of the cooling lines from the CPU and noted that it was very warm.
Pulled the cooling block off the cpu and as expected the CPU was hot. Allowed the cpu to cool and with the power supply off cooled-down the cpu further with an inverted can of dusting air. Once the frost has dissipated from the CPU, powered-up the power supply and attempted to boot while monitoring the cpu temp (with my finger). The temp went from very cold to very hot to the touch and then immediate shutdown, elapsed time ~ 5 seconds.
At this point, I buttoned-up the system and here we are. I cannot get far enough into the boot process to perform any diags. One note however, the battery back-up indicated a large power surge during boot. This is something I had not monitored in the past so I am unsure whether this is a normal state during boot.
Only the Mouse and Keyboard were connected during the last 2 boot attempts. All advice and help is appreciated.
