- Jun 4, 2013
- CALIFORNIA
so im big at gaming and love games but so many reviews or benchamarks about which one to pick help pls!
Bursting something off is not an actual thing in the English language manu. You can't do that.
The 4770K beats the 8350 hands down. The 8350 "competes" with the 4670K.
^This, gaming wise, as soon as you go xFire/SLI with high end GPU's, i5/i7 kill the AMD FX.
Not according to Anandtech...you need 3 or 4 (with a PLX board) to see a meaningful difference.
This is in the present though, the i5 is certainly more future proofed.
I am going to build a new system in a few months, and I am facing the same decisions.I have a FX 6300 overclocked to 4.4g.I have a 660SC, but with a 670 gpu or higher, games and fps would not be a problem for most games on ultra.There are a handful of games that are more cpu intensive vs gpu.Out of those games your still going to get 40 -50 fps with a overclocked FX and a good gpu.I went to many sites comparing benchmarks, and a overclocked 8350 will give you good performance.With that said, here is my dilemma.
With Haswell it looks like Intel did not change the manufacturing process of the thermal paste. Haswell still uses paste instead of solder between the IHS and die.So the question you might ask yourself, I know I am.Should you go with Haswell, and just delid your cpu.Easier said than done, but that is another option.There are some videos on this procedure, but my question is what is the best way, and is it risky?
You need to look a little better. BF3 was just ONE of the examples in your link. AvP does shows the same behavior I am speaking of. The other games you listed from the Tom's link are also known CPU hogs. Again, it depends on the title and settings used.^Yep, but it's 1 out of 5 or 10.
I've linked a few above, but trust me, I checked more than 20 games CPU benchmarks, and if most of them are already bottleneck by the FX now, what about next year?
If you check the benchsmarks I linked, you'll see that even the i7 920, which is something like 3 years old and runs at 2.66GHz...) does better than the FX8350 in many cases.
If you game, get a i5 4670k: no need for HT, and due to the fact that it produces less heat, it should OC higher than the i7 while staying in a tolerable temp range?
Honestly. I don't care. In 5 minutes of searching I have found enough to have a quality counterpoint. Thanks though, but don't waste your time. It depends on the title, that is quite clear.
I dont. Nor do I know what that has to do with anything in this thread.I can`t wait for next years game ports from xbox and ps. if you know what i mean....
