- Jul 14, 2003
- Thread Starter
- #41
That 200mm fan doesn't move crap. It's only 110 CFM.
You have 3 times the intake than exhaust, and coming from 3 different directions. Your airflow is a swirling heat sh1tstorm because there is so much going on that the heat doesn't have a chance to rise to your exhaust. It just keeps getting whipped around the case.
Smoother flow, is the WTG.
Even if you added fans like Johan suggested, chances are it will still throttle, maybe just not as much. The board is sub standard for an 8 core FX.
Its already not throttling under the same load it was previously, in regard to games at least. Getting some fans on the VRM/socket, optimizing the airflow, etc should just help further stabilize that from what i can tell with the testing i did.
Interesting comment on the airflow though im pretty confident in the redone setup especially compared to how it is currently. Im sure the big *** zotac amp! extreme 980ti seperating the bottom half of the case from the top half isn't helping lol. Its like a divider in there.
So i guess there we go. Hi-ho silver, awayyyyy.
