- Oct 29, 2012
Re applying the TIM was the first thing i tried, i cleaned the cpu and heat sink with rubbing alcohol, the first time i applied a pea sized dot amount center of chip, 2nd time i cut it back to half pea sized center of chip, when tightening down heat sink i did the cross method, i seem to get same results both times.
I am guessing i should be 50 under load ? I will pickup one more case fan and see if it helps
Hm. A bit more airflow could help. You should be at about 50-54c under max load on the 212 even without undervolting. See, I would have a hard time telling ya-- My cases always have excessive air flow, so the temps inside are great A good way to test if you need more case flow is to pop off the side and blow a large fan (Like an oscilating fan or a box fan) directly into the case
If your temps have a substantial change then you can probably surmise your case's temps are at least partially responsible
