- Oct 27, 2004
- Upstate NY and NYC
Can someone confirm that the Gigabyte GA-X79-UD7 or GA-X79-UD5 supports the following link speeds with 3-way cards?
x16 - x16 - x8
Getting conflicting information from NewEgg (saying x16 - x8 -x16 -x8), which we know isn't possible on the X79 chipset.
Looking at manual:
http://download.gigabyte.us/FileList/Manual/mb_manual_ga-x79-ud7_e.pdf
It has a component map that clear shows at 1 slot dedicated at x16 at all times. The other x16 is "switchable". Down in the manual on page 10, it says:
Ok, that makes sense. PCIEX8_2 is the "4th" slot FYI. So, when the 4th slot is populated, it sounds like it drops PCIEX16_2 (the 3rd slot in teh system) down to x8 for a total of x16-x8-x8-x8. That makes absolute perfect sense.
But behold, then I read this in the manual, just a couple of lines down on the same page:
Whaaa? Now we are at x8-x8-x8-x8 in 4-way, and 3-way modes?
Please, can someone with 3-way SLI or Crossfire confirm the link speeds on the UD7 or the UD5? I plan on only running 3-way, for now (see sig).
Thanks!
x16 - x16 - x8
Looking at manual:
The PCIEX8_2 slot shares bandwidth with the PCIEX16_2 slot. When the PCIEX8_2
slot is populated, the PCIEX16_2 slot will operate at up to x8 mode.
Support for 4-Way/3-Way/2-Way AMD CrossFireX™/NVIDIA SLI technology
* The PCIEX16 slots operate at up to x8 mode when 4-Way/3-Way AMD
CrossFireX™/NVIDIA SLI is enabled.
Thanks!
