- Aug 28, 2010
There is a little clip sealing the motor. I need to open it, but as I did with previous AP-15 I have, the clip is easy to bend and I end up with a silent motor (after lubrication) but an annoying noise of the clip rubbing the metal.
I just ordered 6 AP-29 and after the PWM mod, one of them makes a really annoying noise...
Do you guys know any tool to open these fan properly? I bought something used for these kind of clip but much bigger...
