- Nov 12, 2002
- Rootstown, OH
So I'm setting up Gentoo on a T400 Thinkpad for the first time. EDIT: I ended up babbling a bit, my question is at the bottom if you want to skip to that.
I'm doing so thru the Ubuntu 8.10 livecd, because I've heard things don't go well with the Gentoo CD due to the T400's CD drive interface. I followed the alternate install guide to get going, I'm chroot'ed, and things are going well - its pretty neat being on a livecd, setting up another OS from it, while using openoffice to write a paper for school in the meantime. When I'm done, I'll have Gentoo dual-booting with Windows XP.
The T400 has a core 2 duo and I read that gcc-4.3.2 lets you use march=core2 for further optimization, rather than march=prescott which is the recommended safe setting with gcc-4.1.2 that comes with the latest stage3 tarball. So I've upgraded to gcc-4.3.2 alright, and cleaned out the old gcc.
I really should be working on this paper for school, so rather than doing the revdep-rebuild route after upgrading gcc, I opted for emerge -e system - I have some time, and I was curious how this new core2duo @2.53Ghz compiles compared to the Pentium [email protected] I had gentoo on previously. LOTS faster.
So anyways, my question. After doing an emerge -e system I'm left with a slew of /etc/._cfg* files which need updated (about 28). How do other Gentoo users handle these files? A lot of them I don't know what they are. Occasionally there is one I know I have manually modified, so I'll compare the new to the old manually by using nano to look at the files and then make the appropriate changes in the new version of the file and overwrite the old version. But most of the files I have never seen before and/or I don't understand what they do and I've never made changes to them, I think - should I overwrite all the old versions of these with the new versions? This is a cumbersome part of Gentoo I remember from the last time I had it installed, so I ask because I'm probably doing something wrong or theres a better way to handle these files.
Thanks for any input or guidance.
